hi everyone, i need a litle help that is driving me crazy , on this screenshoot on red dot does this mean that i have QUADCHANNEL enabled ?
becouse i have 8 4gb modules and using the 32gb CPUZ does not show quad channel enable its says nothing only if i have 4 X 4gb its says quad
i bought aida64 to confirm this so could someone please telme if that quad channel on the memory type means its enabled ?
regards
thanks, but if it saying quad channel must be ?
imagine if it was in single or dual will it show on that parameter the actual channel ?????
thanks in advance
cheers
In single or dual channel mode it would say "Single Channel DDR4-2800" or "Dual Channel DDR4-2800". Your memory configuration uses quad channel mode, we can confirm that based on your screen shot.
