Nebulaner Posted February 25, 2016 Posted February 25, 2016 Hi, got a Asrock Extreme 11 X79 P3.30 Bios with Aida64 Extreme 5.60.3700 (07.12.2015) and the only Fan RPM Aida64 will show is the South Bridge Fan. I need the CPU Fan RPM. In the Bios i can see the Values (3300 RPM) and i am using a "normal" Intel Boxed PWM Cooler. Thank you for your help Quote
Fiery Posted February 26, 2016 Posted February 26, 2016 Do you have the fan connected to the CPU1 or CPU2 fan header? AIDA64 may be able to pick it up if you connect it to the other CPU fan header. Regards, Fiery Quote
Nebulaner Posted February 26, 2016 Author Posted February 26, 2016 Hi Fiery, the South Bridge Fan RPM is displayed the whole time, i noticed that the CPU Fan RPM is displayed but only for a couple of seconds and then disappears. CPU Fan Speed is 2500 RPM and the Fan is turning constant. Is there a need for adjustment or tweaking of settings ? Quote
Fiery Posted February 26, 2016 Posted February 26, 2016 Are you running ASRock's own monitoring software in the background? It may interfere with AIDA64, especially about the fan muxing that your motherboard uses. Quote
