IA64 Posted February 29, 2016 Posted February 29, 2016 Hello, AIDA64 used to work fine on my Xperia Z but on my Sony Z5 Premium it doesn't refresh or update the batter discharge/charge rate every 1 sec. I have to minimize the application and restore it to get the new one. Update interval is set to 1 sec and all other parameters are updating correctly. Tried another Z5 Premium and same issue. Thanks. Quote
Fiery Posted March 1, 2016 Posted March 1, 2016 AIDA64 uses standard Android Battery API to measure battery charge rate and other battery parameters. Sometimes, on certain devices the Android Battery API fails to refresh the battery readings in real-time, but instead does it once per 5 seconds or once per 10 seconds only. So what you experience on your device is a limitation of the Android platform that Sony prepared for your phone, and not an AIDA64 app bug. Regards, Fiery Quote
IA64 Posted March 2, 2016 Author Posted March 2, 2016 Alright. I was a bit puzzled because both Sony Z and Z5 premium are on 5.1.1. Thanks for the clarification. Quote
IA64 Posted March 13, 2016 Author Posted March 13, 2016 Just updated to Android 6.0 and this feature has gone for good. Any chance to have it back in the future ? Thanks, Karim Quote
Fiery Posted March 13, 2016 Posted March 13, 2016 Just updated to Android 6.0 and this feature has gone for good. Any chance to have it back in the future ? Thanks, Karim It is because for some reason Sony decided to remove that functionality from the Android 6.0 platform for your phone. It may be possible to get around this limitation, but in order to let us check it, we'd need a report of your current configuration. Please submit a report from the About page, and we'll check it out right away. Quote
IA64 Posted March 14, 2016 Author Posted March 14, 2016 It is because for some reason Sony decided to remove that functionality from the Android 6.0 platform for your phone. It may be possible to get around this limitation, but in order to let us check it, we'd need a report of your current configuration. Please submit a report from the About page, and we'll check it out right away. Report submitted. Thanks. Quote
Fiery Posted March 14, 2016 Posted March 14, 2016 Report submitted. Thanks. Thank you! We'll fix the issue in the next AIDA64 app update. 1 Quote
Vadim Posted August 28, 2019 Posted August 28, 2019 Same problem on my Samsung galaxy note 8 - Android 9. It doesn't refresh or update the batter discharge/charge rate every 1 sec. Update interval is set to 1 sec and all other parameters are Not updating correctly. Can you please tell me what is wrong. Thank you Quote
Fiery Posted August 29, 2019 Posted August 29, 2019 On 8/28/2019 at 9:58 AM, Vadim said: Same problem on my Samsung galaxy note 8 - Android 9. It doesn't refresh or update the batter discharge/charge rate every 1 sec. Update interval is set to 1 sec and all other parameters are Not updating correctly. Can you please tell me what is wrong. Thank you That's due to a platform constraint. The standard Android Battery API itself doesn't update the values in a greater frequency. Quote
