Can AIDA64 be installed and booted from a USB (like a linux live dvd) and used to check the harware specs of a laptop with no OS installed (blank HDD before installing OS)? This is so that the correct drivers can be sourced and downloaded before the install of the OS (Windows 7)
You can use AIDA64 under bootable Windows, like Windows PE or BartPE. You cannot use it without any form of Windows though.
