AIDA64 Extreme v5.70.3800 cant recognize my motherboard
Hi,
I have a motherboard that I cannot identify.  I tried running AIDA64 Extreme v5.70.3800 but it comes up with "Motherboard Name Unknown".  Can anyone point me in the right direction to identify it?  Google searches on the Motherboard ID string produce too many hits.
Dough
Motherboard Properties:
            Motherboard ID      63-0100-000001-00101111-122211-Chipset$A271T007_BIOS DATE: 06/17/14 17:33:35 VER: 04.06.05
        Front Side Bus Properties:
            Bus Type      BCLK
            Real Clock      100 MHz
            Effective Clock      100 MHz
        Memory Bus Properties:
            Bus Type      Dual DDR3 SDRAM
            Bus Width      128-bit
            DRAM:FSB Ratio      20:3
            Real Clock      667 MHz (DDR)
            Effective Clock      1333 MHz
            Bandwidth      [ TRIAL VERSION ] MB/s
        Chipset Bus Properties:
            Bus Type      Intel Direct Media Interface v2.0
Debug - PCI
        B00 D00 F00:      Intel Sandy Bridge-DT - Host Bridge/DRAM Controller
        Offset 000:      86 80 00 01 06 00 90 20 09 00 00 06 00 00 00 00
        Offset 010:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 020:      00 00 00 00 00 00 00 00 00 00 00 00 DA 19 07 A2
        Offset 030:      00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
        Offset 040:      01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
        Offset 050:      11 02 00 00 11 00 00 00 00 00 00 00 01 00 00 DB
        Offset 060:      05 00 00 F8 00 00 00 00 01 80 D1 FE 00 00 00 00
        Offset 070:      00 00 00 FF 00 00 00 00 00 0C 00 FF 7F 00 00 00
        Offset 080:      10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00
        Offset 090:      01 00 00 00 01 00 00 00 01 00 50 1F 01 00 00 00
        Offset 0A0:      01 00 00 00 01 00 00 00 01 00 60 1F 01 00 00 00
        Offset 0B0:      01 00 A0 DB 01 00 80 DB 01 00 00 DB 01 00 A0 DF
        Offset 0C0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0D0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0E0:      09 00 0C 01 96 C0 80 E2 90 00 00 14 00 00 00 00
        Offset 0F0:      00 00 00 00 00 00 00 00 B8 0F 06 00 00 00 00 00
        B00 D02 F00:      Intel Sandy Bridge-DT - Integrated Graphics Controller (DT GT1)
        Offset 000:      86 80 02 01 07 00 90 00 09 00 00 03 00 00 00 00
        Offset 010:      04 00 80 F7 00 00 00 00 0C 00 00 E0 00 00 00 00
        Offset 020:      01 F0 00 00 00 00 00 00 00 00 00 00 DA 19 07 A2
        Offset 030:      00 00 00 00 90 00 00 00 00 00 00 00 0B 01 00 00
        Offset 040:      09 00 0C 01 96 C0 80 E2 90 00 00 14 00 00 00 00
        Offset 050:      11 02 00 00 11 00 00 00 00 00 00 00 01 00 A0 DB
        Offset 060:      00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 070:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 090:      05 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0A0:      00 00 00 00 13 00 06 03 00 00 00 00 00 00 00 00
        Offset 0B0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0D0:      01 A4 22 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0E0:      00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
        Offset 0F0:      00 00 00 00 00 00 00 00 00 00 06 00 18 80 43 DA
        B00 D16 F00:      Intel Cougar Point PCH - Manageability Engine Interface 1 [b-2]
        Offset 000:      86 80 3A 1C 06 00 10 00 04 00 80 07 00 00 80 00
        Offset 010:      04 90 D0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 50 00 00 00 00 00 00 00 0B 01 00 00
        Offset 040:      45 02 00 1E 10 00 01 80 06 01 00 62 F0 0F 00 10
        Offset 050:      01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
        Offset 060:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      00 00 00 00 00 00 00 00 00 00 00 00 05 00 80 00
        Offset 090:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0A0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0B0:      00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
        Offset 0C0:      6A 2A 5E 4A 76 98 B8 39 15 8A 46 7F 79 C1 3A F7
        Offset 0D0:      45 33 3E 83 21 30 DB F8 5F 09 E2 EA 0C 4A 2B 68
        Offset 0E0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0F0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B00 D1A F00:      Intel Cougar Point PCH - USB EHCI #2 Controller [b-3]
        Offset 000:      86 80 2D 1C 06 00 90 02 05 20 03 0C 00 00 00 00
        Offset 010:      00 70 D0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
        Offset 040:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 050:      01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
        Offset 060:      20 20 81 07 00 00 00 00 01 00 00 00 00 20 00 C0
        Offset 070:      00 00 DF 3F 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      00 00 80 00 11 88 0C 93 30 0D 00 24 00 00 00 00
        Offset 090:      00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
        Offset 0D0:      00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
        Offset 0E0:      00 00 00 00 01 02 08 91 3B 0C B2 20 48 C4 1D 0A
        Offset 0F0:      00 00 00 00 88 85 80 00 87 0F 07 08 08 17 5B 20
        B00 D1B F00:      Intel Cougar Point PCH - High Definition Audio Controller [b-3]
        Offset 000:      86 80 20 1C 06 00 10 00 05 00 03 04 10 00 00 00
        Offset 010:      04 00 D0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 020:      00 00 00 00 00 00 00 00 00 00 00 00 DA 19 30 A1
        Offset 030:      00 00 00 00 50 00 00 00 00 00 00 00 05 01 00 00
        Offset 040:      01 00 00 45 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 050:      01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 060:      05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 070:      10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
        Offset 0C0:      00 04 02 01 02 24 00 40 00 0C A3 82 10 00 33 02
        Offset 0D0:      00 0C A3 02 10 00 33 02 00 00 00 00 00 00 00 00
        Offset 0F0:      00 00 00 00 00 00 00 00 87 0F 07 08 00 00 00 00
        B00 D1C F00:      Intel Cougar Point PCH - PCI Express Port 1 [b-3]
        Offset 000:      86 80 10 1C 07 00 10 00 B5 00 04 06 10 00 81 00
        Offset 010:      00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 20
        Offset 020:      F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 40 00 00 00 00 00 00 00 10 01 10 00
        Offset 040:      10 80 42 01 00 80 00 00 00 00 10 00 12 4C 11 01
        Offset 050:      03 00 01 10 00 B2 04 00 00 00 00 00 00 00 00 00
        Offset 060:      00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00
        Offset 070:      01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 090:      0D A0 00 00 DA 19 07 A2 00 00 00 00 00 00 00 00
        Offset 0A0:      01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0D0:      00 00 00 01 02 0B 00 00 00 80 11 81 00 00 00 00
        Offset 0E0:      00 3F 00 00 00 00 00 00 03 00 00 00 00 00 00 00
        B00 D1C F01:      Intel Cougar Point PCH - PCI Express Port 2 [b-3]
        Offset 000:      86 80 12 1C 07 00 10 00 B5 00 04 06 10 00 81 00
        Offset 010:      00 00 00 00 00 00 00 00 00 02 02 00 E0 E0 00 00
        Offset 020:      F0 FF 00 00 01 F0 01 F0 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 40 00 00 00 00 00 00 00 11 02 10 00
        Offset 040:      10 80 42 01 00 80 00 00 00 00 10 00 12 3C 11 02
        Offset 050:      42 00 11 70 00 B2 0C 00 00 00 40 00 00 00 00 00
        Offset 0E0:      00 03 00 00 00 00 00 00 01 00 00 00 00 00 00 00
        B00 D1C F02:      Intel Cougar Point PCH - PCI Express Port 3 [b-3]
        Offset 000:      86 80 14 1C 07 00 10 00 B5 00 04 06 10 00 81 00
        Offset 010:      00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 00
        Offset 020:      C0 F7 C0 F7 F1 FF 01 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 40 00 00 00 00 00 00 00 12 03 10 00
        Offset 040:      10 80 42 01 00 80 00 00 00 00 10 00 12 3C 11 03
        Offset 050:      40 00 12 F0 00 B2 14 00 00 00 40 00 00 00 00 00
        Offset 070:      02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B00 D1D F00:      Intel Cougar Point PCH - USB EHCI #1 Controller [b-3]
        Offset 000:      86 80 26 1C 06 00 90 02 05 20 03 0C 00 00 00 00
        Offset 010:      00 60 D0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
        Offset 060:      20 20 01 06 00 00 00 00 01 00 00 00 00 20 00 C0
        Offset 0E0:      00 00 00 00 02 20 00 00 E0 00 08 10 00 98 31 00
        B00 D1F F00:      Intel H61 PCH - LPC Interface Controller [b-3]
        Offset 000:      86 80 5C 1C 07 00 10 02 05 00 01 06 00 00 80 00
        Offset 040:      01 04 00 00 80 00 00 00 01 05 00 00 10 00 00 00
        Offset 050:      F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 060:      8B 83 8B 8A D0 00 00 00 80 80 85 8A F8 F0 00 00
        Offset 070:      78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0
        Offset 080:      00 00 00 14 01 0A FC 00 00 00 00 00 00 00 00 00
        Offset 090:      00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00
        Offset 0A0:      08 0E 80 00 48 38 06 00 00 47 00 00 00 00 00 80
        Offset 0D0:      33 22 11 00 67 45 00 00 CF FF 00 00 08 00 00 00
        Offset 0E0:      09 00 0C 10 00 00 00 00 5F 0A 64 0C 00 00 00 00
        Offset 0F0:      01 C0 D1 FE 00 00 00 00 87 0F 07 08 00 00 00 00
        B00 D1F F02:      Intel Cougar Point PCH - SATA Controller [b-3]
        Offset 000:      86 80 00 1C 07 00 B0 02 05 8F 01 01 00 00 00 00
        Offset 010:      11 F1 00 00 01 F1 00 00 F1 F0 00 00 E1 F0 00 00
        Offset 020:      D1 F0 00 00 C1 F0 00 00 00 00 00 00 DA 19 07 A2
        Offset 030:      00 00 00 00 70 00 00 00 00 00 00 00 10 04 00 00
        Offset 040:      00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 050:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 070:      01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 090:      00 3D 02 82 83 01 00 3D 08 42 5C 01 01 00 00 00
        Offset 0A0:      E0 00 00 00 00 00 39 00 00 00 00 00 00 00 00 00
        Offset 0B0:      13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0C0:      00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
        B00 D1F F03:      Intel Cougar Point PCH - SMBus Controller [b-3]
        Offset 000:      86 80 22 1C 03 00 80 02 05 00 05 0C 00 00 00 00
        Offset 010:      04 50 D0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 020:      41 F0 00 00 00 00 00 00 00 00 00 00 DA 19 07 A2
        Offset 030:      00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00
        Offset 040:      01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 060:      03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
        Offset 080:      04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B00 D1F F05:      Intel Cougar Point PCH - SATA 2-Port Controller [b-3]
        Offset 000:      86 80 08 1C 05 00 B0 02 05 85 01 01 00 00 00 00
        Offset 010:      B1 F0 00 00 A1 F0 00 00 91 F0 00 00 81 F0 00 00
        Offset 020:      71 F0 00 00 61 F0 00 00 00 00 00 00 DA 19 07 A2
        Offset 090:      00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B00 D1F F06:      Intel Cougar Point PCH - Thermal Management Controller [b-3]
        Offset 000:      86 80 24 1C 00 00 10 00 05 00 80 11 00 00 00 00
        Offset 010:      04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 030:      00 00 00 00 50 00 00 00 00 00 00 00 0B 03 00 00
        Offset 040:      05 00 A0 DF 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 050:      01 00 23 00 08 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B02 D00 F00:      Realtek RTL8168/8111 PCI-E Gigabit Ethernet Adapter
        Offset 000:      EC 10 68 81 07 00 10 00 06 00 00 02 10 00 00 00
        Offset 010:      01 E0 00 00 00 00 00 00 0C 40 00 F0 00 00 00 00
        Offset 020:      0C 00 00 F0 00 00 00 00 00 00 00 00 DA 19 68 81
        Offset 030:      00 00 00 00 40 00 00 00 00 00 00 00 11 01 00 00
        Offset 040:      01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00
        Offset 050:      05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 070:      10 B0 02 02 C0 8C 90 05 00 50 10 00 11 7C 07 00
        Offset 080:      42 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 090:      00 00 00 00 1F 00 00 00 10 00 00 00 00 00 00 00
        Offset 0B0:      11 D0 03 00 04 00 00 00 04 08 00 00 00 00 00 00
        Offset 0D0:      03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        B03 D00 F00:      VIA USB 3.0 eXtensible Host Controller
        Offset 000:      06 11 32 34 07 00 10 00 03 30 03 0C 10 00 00 00
        Offset 010:      00 00 C0 F7 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 020:      00 00 00 00 00 00 00 00 00 00 00 00 DA 19 43 42
        Offset 030:      00 00 00 00 80 00 00 00 00 00 00 00 0B 01 00 00
        Offset 060:      30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 080:      01 90 C3 F9 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 090:      05 C4 80 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 0C0:      00 00 00 00 10 00 02 00 01 89 64 01 00 28 10 00
        Offset 0D0:      12 50 06 00 00 00 12 10 00 00 00 00 00 00 00 00
        Offset 0E0:      00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00
        Offset 0F0:      00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
        PCI-8086-0100:      Intel SNB/IVB/HSW/CRW/BDW/SKL/KBL MCHBAR @ FED10000h
        Offset 4000:      99 79 18 00 54 54 14 0A 20 32 02 0A 90 56 00 00
        Offset 4010:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 4020:      05 00 10 00 21 20 20 20 01 00 0E 00 00 00 00 00
        Offset 4280:      00 00 00 00 00 00 0C 00 00 00 00 00 44 00 00 00
        Offset 4290:      80 40 00 00 0F 98 00 00 50 14 6B 5A 10 02 00 00
        Offset 42A0:      01 10 00 00 00 72 F9 41 00 00 00 00 01 00 00 00
        Offset 4400:      99 79 18 00 54 54 14 0A 20 32 02 0A 90 56 00 00
        Offset 4410:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 4420:      05 00 10 00 21 20 20 20 00 00 0E 00 00 00 00 00
        Offset 4680:      00 00 00 00 00 00 0C 00 00 00 00 00 44 00 00 00
        Offset 4690:      80 40 00 00 0F 98 00 00 50 14 6B 5A 10 02 00 00
        Offset 46A0:      01 10 00 00 00 72 F9 41 00 00 00 00 01 00 00 00
        Offset 4800:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 4810:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 4A80:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 4A90:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 5000:      24 00 00 00 08 00 60 00 08 00 60 00 00 00 60 00
        Offset 5010:      00 00 00 00 00 00 10 08 00 00 00 00 00 00 00 00
        Offset 5880:      E7 71 91 CA 00 00 00 00 D0 DA E4 00 00 00 00 00
        Offset 5890:      6F 08 63 00 71 72 61 00 00 00 00 00 00 00 00 00
        Offset 58A0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 58B0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 58C0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 58D0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 58E0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 58F0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 5900:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 5910:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 5920:      00 00 00 00 10 00 00 00 F1 A8 32 08 CD 62 7F 00
        Offset 5930:      08 02 E0 01 A0 02 0A 00 03 10 0A 00 1B CA 3F 11
        Offset 5940:      00 00 00 00 6A 00 00 00 29 11 00 00 00 00 00 00
        Offset 5950:      00 00 00 00 00 00 04 00 00 21 01 60 00 10 00 00
        Offset 5960:      79 05 00 00 5F E4 5F FC 4C E0 5F FC 9D C4 60 96
        Offset 5970:      BC 0A 00 00 BC 0A 00 00 26 00 00 00 26 00 00 00
        Offset 5980:      25 00 00 00 40 2C 62 04 00 00 00 00 00 00 00 00
        Offset 5990:      FF 00 00 00 FF 00 00 00 16 11 11 00 00 14 66 00
        Offset 59A0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 59B0:      10 03 00 00 94 14 14 18 04 01 00 00 94 14 14 18
        Offset 59C0:      00 00 41 88 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 5E00:      05 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
        Offset 5E10:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        PCI-8086-1C24:      Intel 5/6/7/8/9/10-series PCH TBARB @ DFA00000h
        Offset 00:      01 BA 00 EB 2B 3A 00 00 FD 00 00 00 00 00 C0 00
        Offset 10:      00 00 80 19 87 DE 8C 80 00 00 E0 10 00 00 00 00
        Offset 20:      00 00 59 0B 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 30:      00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 80
        Offset 40:      01 02 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 50:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 60:      00 00 00 00 00 00 00 00 00 00 00 00 20 1B 16 05
        Offset 70:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset 80:      01 01 00 04 6C 6C 00 FF 00 00 00 00 00 00 00 00
        Offset 90:      F6 85 A1 08 00 00 00 00 00 00 00 00 00 00 00 00
        Offset A0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset B0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset C0:      01 01 00 00 00 00 00 FF 00 00 00 00 00 00 00 00
        Offset D0:      00 00 00 00 00 00 00 00 37 00 C0 00 00 00 00 00
        Offset E0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
        Offset F0:      00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Debug - Video BIOS
        C000:0000      U.s...000000000000.#.-"x@...00IBM VGA Compatible BIOS. .t.......
        C000:0040      PCIR............................"...R.Z.b.j.r.....t.............
        C000:0080      ................=............................................DH.
        C000:00C0      ....DH.....DH....0DH.....DI.....DI.....DJ.....DJ....0DJ.....DI..
        C000:0100      ..0DI.....DJ.....DK.....DK.....DK....0.L......L......L....0.L...
        C000:0140      ...M......M.....0.J..2.n..4....8....:....<....A.J..C.n..E....I..
        C000:0180      ..K....M....P J..R n..T ...X ...Z ...\ ...`.5..a.5..b 5..c.O..d.
        C000:01C0      O..e O..f.i..g.i..h i..i....j....k ...l....m....n ...o....p....q
        C000:0200      ...}....~.... ........ .-..`............ .1..l...........rQ..
        C000:0240      n(U...!....... ....`"........... ....@.......... .1X. (.........
        C000:0280      V. .1X. .P........d..@A.&0..6.......... A. 0.`........0*..Q.*@0p
        C000:02C0      .........4..Q.*@..........H?@0b.2@@.........h[..r.<P............
        C000:0300      ........E............................................E..........
        C000:0340      .........................For Evaluation Use Only....(........c-'
        C000:0380      (.+.................................................(........c-'
        C000:03C0      (.+.................................................P........c_O
Debug - Unknown
        Motherboard      63-0100-000001-00101111-122211-Chipset$A271T007_BIOS DATE: 06/17/14 17:33:35 VER: 04.06.05
        Motherboard      DMIMOBO: N/A N/A
        Motherboard      DMISYS: N/A N/A
        Motherboard      Unknown
I'm afraid we also couldn't find out what motherboard you've got :( If it's possible, try to have a visual inspection of the motherboard PCB and find markings that may lead to the manufacturer's identify or the part number (model ID) of the motherboard.
  • 10 months later...
I have the same issue.  I just completed a build with a core i7-6700k using an Asus Prime Z270-A Rev 1.xx.  When I click on Motherboard in AIDA 5.80.4000 it shows the following:
Field Value
Motherboard ID 63-0100-000001-00101111-051315-Chipset$0AAAA000_BIOS DATE: 12/27/16 21:53:33 VER: 05.0000C
Motherboard Name Unknown Motherboard
Bus Type BCLK
Real Clock 100 MHz
Bus Type Dual DDR4 SDRAM
Bus Width 128-bit
DRAM:FSB Ratio 32:3
Real Clock 1067 MHz (DDR)
Effective Clock 2133 MHz
Bandwidth 34133 MB/s
Bus Type Intel Direct Media Interface v3.0
