Wrong CPU temperature (Asus P8H67-M Pro)
Katsuyori
The CPU temperature is incorrect. The core temperatures are OK, the values are identical with CoreTemp results, but the CPU temperature is incorrect. While the cores are about 30/35 degrees C each, the CPU temperature reads 90 degrees C.
At first I thought that CPU shows the sum of the 4 core temps, but definitely this is not the case.
My CPU is an Intel core i5-2400. The M/B is an Asus P8H67-M PRO. I'm running AIDA64 Extreme v1.60.1369 Beta on Windows 7 Professional x64.
Thanks
1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.
2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic.
ISA Sensor Dump:
------[ AIDA64 v1.60.1369 Beta ]------
------[ Microsoft Windows 7 Professional 6.1.7601 (64-bit) ]------
Motherboard ID : 63-0100-000001-00101111-020510-Chipset$0AAAA000_BIOS DATE: 02/05/10 19:13:52 VER: 08.00.10
Motherboard Model : Asus P8H67-M Pro
Motherboard Chipset : Intel Cougar Point H67, Intel Sandy Bridge
DMI MB Manufacturer : ASUSTeK Computer INC.
DMI MB Product : P8H67-M PRO
DMI MB Version : Rev 1.xx
DMI MB Serial : MF70B2G08701152
DMI SYS Product : System Product Name
DMI SYS Version : System Version
DMI SYS Serial : System Serial Number
DMI BIOS Version : 0806
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 2Eh
Winbond SuperIO HWMonitor Port = 0290h
Winbond SuperIO Device ID = C333h
Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0]------
0000 04 99 04 46 00 FF FF FF FF FF FF FF FF FF FF FF
0010 04 99 00 99 46 99 FF FF 50 00 00 00 00 85 00 00
0020 98 81 D5 D4 7E FF 27 19 FF FF FF DA 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
0040 01 00 40 DF FF 00 3F FF 2D FF FF FF 18 05 02 A3
0050 FF FF FF FF FF FF FF FF C1 FF FF FF FF 01 00 FF
0060 00 FF FF FF FF 01 07 FF FF FF FF FF FF FF FF FF
0070 00 0A 00 1B 80 1B 80 1B 80 FF FF FF FF FF FF FF
0080 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00
0090 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4
00A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 01 01
00B0 00 00 00 00 00 00 2B 00 1C 00 00 34 28 00 C4 FF
00C0 01 00 00 00 00 00 00 00 00 05 07 FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Reg$20 CPU Core: r = 152, r*0.016 = 2.43
Reg$21 CPU Aux: r = 129, r*0.016 = 2.06
Reg$22 +3.3 V: r = 213, r*0.016 = 3.41
Reg$23 +5 V: r = 212, r*0.016 = 3.39
Reg$24 +12 V: r = 126, r*0.016 = 2.02
Reg$25 -12 V: r = 255, r*0.016 = 4.08
Reg$26 -5 V: r = 39, r*0.016 = 0.62
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1]------
0000 0C 00 40 01 01 01 01 3C FF 99 FF FF 00 FF FF FF
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0020 00 1E 46 46 46 FF FF 99 FF FF FF FF FF FF FF FF
0030 FF 00 FF FF 00 4B FF FF 02 01 00 00 00 00 00 00
0040 FF FF FF FF FF D5 03 FF FF FF FF FF FF FF 02 FF
0050 4A 00 02 4C 00 51 00 FF FF FF FF FF FF FF FF FF
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2]------
0000 0C 32 40 01 01 01 01 3C FF 46 FF FF 00 FF FF FF
0020 00 14 41 46 46 FF FF 33 B2 FF FF FF FF FF FF FF
0040 FF FF FF FF FF A0 04 FF FF FF FF FF FF FF 02 FF
0050 4D 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3]------
0040 FF FF FF FF FF 10 04 FF FF FF FF FF FF FF 02 FF
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
0020 FF FF FF 90 3E 90 3E ED AF FF FF FF FF FF FF FF
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 3F 00 00 FF FF FF FF FF FF FF FF FF FF FF 02 FF
0050 33 13 FF FF 00 00 00 FF 00 DE 1F B3 09 FF FF FF
0060 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5]------
0000 FF FF 00 00 00 00 FF FF FF FF FF FF FF 00 00 FF
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 FF
0050 D5 D1 80 FF 00 00 00 00 FF FF FF FF FF FF FF FF
0060 00 00 00 00 00 00 07 01 01 FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6]------
0000 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0020 FF 01 02 03 01 01 01 FF 00 00 00 19 19 19 00 FF
0030 2D 0C 23 10 28 14 FF 1F FF 1F 00 00 00 00 00 00
0040 00 00 00 00 02 02 02 FF FF FF FF FF FF FF 02 FF
0050 7F 7F 7F 7F 7F 7F 03 A1 04 A4 04 0E 00 A4 00 A4
0070 7F 7F 50 4B 04 7F 7F 50 4B 04 7F 7F 50 4B 04 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7]------
0000 FF 95 02 10 00 00 00 00 00 59 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 F1 09 F8 80 F8 80 F8 80 01
0020 1D 00 06 00 00 00 EF 64 00 EF 00 00 00 00 00 00
0030 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF
0027 0150 0250 007D 062B 0720
T: 25 66 77 255 25 29
T: 25 78 77 255 25 29
T: 25 88 77 255 25 27
T: 25 88 78 255 25 26
T: 25 88 77 255 25 25
T: 25 89 77 255 25 25
T: 25 89 78 255 25 25
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
SMBus Dump (Full):
------[ GPIO @ isa 0500 ]------
0000 C3 B9 23 B9 C2 6F BF 2E 00 00 00 00 FE 6E 93 E8
0010 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
0020 00 00 08 00 00 00 00 00 00 00 00 00 42 20 00 00
0030 07 00 02 22 34 FF 56 1D 03 7F FE BC 00 00 00 00
------[ SMBus #0 ]------
SMBus Type : Intel ICH
SMBus Port : F000
Can Have SPD: Yes
Scan Type : Full
0000 00 00 00 04 00 00 00 00 00 11 09 00 06 30 04 11 .............0..
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0000 FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF11 FF09 FF00 FF06 FF30 FF04 FF11
0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4.
0010 6C 78 6C 30 6C 11 20 8C 70 03 3C 3C 00 F0 82 05 lxl0l. .p.<<....
0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 01 01 01 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 62 72 ..............br
0080 45 52 53 33 30 30 41 20 20 20 20 20 20 20 20 20 ERS300A
0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ..............
00E0 32 38 38 33 38 32 33 00 00 00 00 00 00 00 00 00 2883823.........
00F0 39 39 30 35 34 30 32 2D 30 30 31 2E 41 30 31 4C 9905402-001.A01L
------[ SMBus Device B00-D53 ]------
Thanks
I have noticed the same issue with this board.. i had thought it was bad motherboard, or bad cpu.. so far both replaced same issue.. bios reports cpu as 60C or higher.. often times real temp software showing 89C in windows..
See this thread http://hardforum.com/showthread.php?t=1602479
This board must be really new to exhibit this issue with no resolutions?
