wiremonkey Posted April 28, 2016 Posted April 28, 2016 The cooling fan labels are incorrect in AIDA64 Extreme. I'm using 5.70.3800 . One of the case fans is labeled Power Supply. Quote
Fiery Posted April 28, 2016 Posted April 28, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Please also let us know exactly which fan label should be renamed, and what the correct label is supposed to be. Thanks, Fiery Quote
