pyrojoe34 Posted May 22, 2016 Posted May 22, 2016 As the title says, AIDA does not seem to see the CPU socket temp from my motherboard (other temps seem to appear correctly), HWINFO64 can see it fine but AIDA does not (I'd rather use AIDA), it only sees the CPU package/core temps, and one other temp from the mobo (It doesn't seem to see the NB temp either though since the MB temp it sees is usually ~35C and the NB would be way hotter than that, so it seems like it's missing the NB temp too). It's not critical since I'm replacing the mobo/cpu soon but it'd be nice to see the temp anyway since I've found the socket will reach the thermal limit before any other components do so I need to base my OC off that temp. AIDA64 beta 5.70.3833 5.70.3854 MB: Gigabyte 990FXA-UD3 (rev: 1.1(I think confirmed version 1.1), firmware: F9) CPU: AMD FX-8120 OS: Win 10 home 64bit (most recent stable build, always kept up to date) Quote
Fiery Posted May 23, 2016 Posted May 23, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
pyrojoe34 Posted May 23, 2016 Author Posted May 23, 2016 ------[ AIDA64 Extreme v5.70.3854 Beta ]------------[ Microsoft Windows 10 Home 10.0.10586.318 (64-bit) ]------------[ Motherboard Info ]------Motherboard ID : 10/22/2012-RD990-SB950-7A66FG06C-00Motherboard Model : Gigabyte GA-990FXA-UD3Motherboard Chipset : AMD 990FX, AMD K15Award BIOS Type : Award Modular BIOS v6.00PGAward BIOS Message : GA-990FXA-UD3 F9DMI MB Manufacturer : Gigabyte Technology Co., Ltd.DMI MB Product : GA-990FXA-UD3DMI MB Version : x.xDMI MB Serial :DMI SYS Manufacturer: Gigabyte Technology Co., Ltd.DMI SYS Product : GA-990FXA-UD3DMI SYS Version :DMI SYS Serial :DMI BIOS Version : F9ITE SuperIO Port = 2EhITE SuperIO HWMonitor Port = 0228h (0228h / 0000h)ITE SuperIO Device ID = 8720h (8720h / 0000h)ITE SuperIO Version = 08h ( 08h / 00h)Winbond SuperIO Port = 00hWinbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h)Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h)Winbond SuperIO Device ID = 0000h (0000h / 0000h)Fintek SuperIO Port = 00hFintek SuperIO HWMonitor Port = 0000h (0000h / 0000h)Fintek SuperIO Device ID = 0000h (0000h / 0000h)SMSC SuperIO Port = 00hSMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h)SMSC SuperIO Device ID = 0000h (0000h / 0000h)ASpeed SuperIO Port = 00h------[ LM78 ISA Sensor Device at 0228 ]------0000 13 00 40 00 FF FF 00 37 FF 87 48 0F 17 C5 B0 FF0010 FF FF FF 72 D7 7F 80 7F 02 03 FF FF FF FF FF FF0020 55 5C CF B9 BF 7B FF 87 CF 22 1E 24 80 A6 BA BA0030 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 000040 7F 7F 7F 7F 7F 7F 5F 74 2D 40 9C 00 FF FF FF FF0050 FF 0E 7F 7F 7F D0 00 00 90 80 06 12 60 00 00 000060 00 14 41 27 90 03 00 FF 00 14 41 23 90 03 00 FF0070 00 14 41 20 90 03 00 FF FF FF FF FF FF FF FF FF0080 50 02 00 00 FF FF 00 00 02 99 00 00 01 00 E2 240090 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF00A0 A4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0029 002A 002BT: 34 30 36T: 34 30 35T: 34 30 35T: 34 30 34T: 34 31 33T: 34 29 32T: 34 29 31T: 34 29 28T: 34 29 27T: 34 28 34 0020 0021 0022 0023 0024 0025 0026 0027 0028V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 1.26250 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 1.26250 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 1.26250 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 1.26250 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 0.87500 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 0.87500 V ]V: 56 5C CF B9 BF 82 FF 87 CF [ VID = 1.26250 V ]V: 3C 5C CF B9 BF 7C FF 87 CF [ VID = 1.26250 V ]V: 3C 5C CF B9 BF 7C FF 87 CF [ VID = 0.95000 V ]V: 3C 5C CF B9 BF 7C FF 87 CF [ VID = 0.87500 V ]------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 000070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000A0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF00B0 00 FF 00 00 FF 00 00 FF 00 00 00 00 00 00 00 0000C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000D0 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF00E0 00 00 00 00 00 00 00 00 00 00 83 19 01 00 00 0000F0 19 0A 02 05 C8 20 80 00 00 04 00 55 08 08 00 00Reg$59VIN0: r = $FFFF, r*0.000046 = 3.0146Reg$5DVIN1: r = $FFFF, r*0.000046 = 3.0146Reg$61VIN2: r = $0000, r*0.000046 = 0.0000Reg$65VIN3: r = $0000, r*0.000046 = 0.0000Reg$69VIN4: r = $0000, r*0.000046 = 0.0000Reg$6DVIN5: r = $0000, r*0.000046 = 0.0000Reg$71VIN6: r = $0000, r*0.000046 = 0.0000Reg$75VIN7: r = $0000, r*0.000046 = 0.0000------[ SB7xx/8xx/9xx PM at 0CD6 ]------0000 0E 00 4F 4A 00 04 00 02 B4 05 04 02 06 21 43 550010 FF 0F 00 00 FF 0F 00 00 00 00 00 00 00 00 00 000020 00 00 D1 FE 01 00 D8 FE 25 0B 00 00 01 0B 00 000030 00 00 00 00 07 00 C0 FE 00 00 00 00 00 00 00 000040 00 00 00 00 00 00 00 80 F1 00 C0 FE 03 00 00 000050 03 00 D0 FE 90 00 00 97 01 FF 15 66 00 05 00 050060 00 08 04 08 08 08 10 08 20 08 B0 00 00 FE B8 000070 00 00 00 00 17 00 00 06 FF FF 01 80 85 01 E0 A00080 9F 3A 06 28 00 00 00 00 30 10 00 00 9E 00 80 000090 02 05 02 0B 0A 00 10 00 00 10 00 10 02 00 00 0000A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000B0 00 00 00 00 00 0B 05 05 08 00 08 40 02 00 53 0000C0 F9 0B 58 40 3C 02 00 00 20 40 28 00 FF FF FF FF00D0 00 00 30 00 00 00 00 00 1E 00 99 00 01 00 10 0300E0 D8 0C 00 00 00 00 00 02 00 00 00 01 03 12 00 7F00F0 9C 03 00 00 00 00 01 21 6C 27 00 00 00 00 00 00------[ ACPI Temperatures & Fans ]------_TZ_.THM0._TMP :_TZ_.THM1._TMP :_TZ_.THR0._TMP :_TZ_.THR1._TMP :_TZ_.TZ00._TMP :_TZ_.TZ01._TMP :_TZ_.RTMP :_TZ_.RFAN :_TZ_.RFAN(0) :_TZ_.RFAN(1) :_SB_.ATKD._HID :_SB_.ATKD.TMPR :_SB_.PCI0.LPC0.EC0_.CCTV :_SB_.PCI0.LPC0.EC0_.LRPM :_SB_.PCI0.LPC0.EC0_.HRPM :_SB_.PCI0.SBRG.EC0_.ECPU :_SB_.PCI0.SBRG.EC0_.TACH(0):_SB_.PCI0.SBRG.EC0_.TACH(1):_SB_.PCI0.SBRG.EC0_.TAH0 :_SB_.PCI0.SBRG.EC0_.TAH1 :_SB_.PCI0.SBRG.EC0_.ST00 :_SB_.PCI0.SBRG.EC0_.SC01 :_SB_.PCI0.SBRG.EC0_.SC02 :_SB_.PCI0.SBRG.EC0_.SC03 :_SB_.PCI0.SBRG.EC0_.SC04 :_SB_.PCI0.SBRG.EC0_.SC05 :_SB_.PCI0.SBRG.EC0_.SC06 :_SB_.PCI0.SBRG.EC0_.TH0R :_SB_.PCI0.SBRG.EC0_.TH1R :_SB_.PCI0.SBRG.EC0_.F0TS :_SB_.PCI0.SBRG.EC0_.F1TS :_SB_.PCI0.PIB_.EC0_.TCRT :_SB_.PCI0.SBRG.EC0_.CTPM :_SB_.PCI0.SBRG.EC__.CPUT :_SB_.PCI0.SBRG.EC__.SYST :_SB_.PCI0.LPC_.EC0_.CTMP :_SB_.PCI0.LPCB.EC0_.CTMP :_SB_.PCI0.LPC_.EC0_.TMP1 :_SB_.PCI0.LPC_.EC0_.TMP2 :_SB_.PCI0.LPC_.EC0_.TMPI :_SB_.PCI0.LPC_.EC0_.TMPV :_SB_.PCI0.LPCB.EC0_.A1TP :_SB_.PCI0.LPCB.EC0_.A2TP :_SB_.PCI0.LPCB.EC0_.FAN0 :_SB_.PCI0.LPCB.EC__.TS1R :_SB_.PCI0.LPCB.EC__.TS2R :_SB_.PCI0.LPCB.EC__.TS3R :_SB_.PCI0.LPCB.EC__.F1FL :_SB_.PCI0.LPCB.EC__.F1FH :_SB_.PCI0.LPCB.EC__.F2FL :_SB_.PCI0.LPCB.EC__.F2FH :_SB_.PCI0.LPC_.H8EC.RTMP :_SB_.PCI0.LPC_.H8EC.LTMP :_SB_.PCI0.LPC_.H8EC.MTMP :_SB_.PCI0.LPC_.H8EC.GTMP :_SB_.PCI0.LPCB.H8EC.CTMP :_SB_.PCI0.LPCB.H8EC.DTMP :_SB_.PCI0.LPCB.H8EC.GTMP :_SB_.PCI0.LPCB.H8EC.ITMP :_SB_.PCI0.LPCB.H8EC.MTMP :_SB_.PCI0.LPCB.H8EC.STMP :_SB_.PCI0.LPCB.H8EC.PFAN :_SB_.PCI0.LPCB.EC0_.OTPC :_SB_.PCI0.LPCB.EC0_.VGAT :_SB_.PCI0.LPCB.EC0_.CHPT :_SB_.PCI0.LPCB.EC0_.CPUT :_SB_.PCI0.LPCB.EC0_.SYST :_SB_.PCI0.LPCB.EC0_.DTS1 :_SB_.PCI0.LPCB.EC0_.DTS2 :_SB_.PCI0.LPCB.EC0_.DIMM :_SB_.PCI0.LPCB.EC0_.FANH :_SB_.PCI0.LPCB.EC0_.FANL :_SB_.PCI0.LPCB.EC0_.CUTP :_SB_.PCI0.LPCB.EC0_.PHTP :_SB_.PCI0.LPCB.EC0_.DIMT :_SB_.PCI0.LPCB.EC0_.INLE :_SB_.PCI0.LPCB.EC0_.PANT :_SB_.PCI0.LPCB.EC0_.F0RM :_SB_.PCI0.LPCB.EC0_.F0DT :_SB_.PCI0.LPCB.EC0_.F1RM :_SB_.PCI0.LPCB.EC0_.F1DT :_SB_.PCI0.SBRG.EC0_.CUTP :_SB_.PCI0.SBRG.EC0_.PHTP :_SB_.PCI0.SBRG.EC0_.DIMT :_SB_.PCI0.SBRG.EC0_.INLE :_SB_.PCI0.SBRG.EC0_.PANT :_SB_.PCI0.SBRG.EC0_.F0RM :_SB_.PCI0.SBRG.EC0_.F0DT :_SB_.PCI0.SBRG.EC0_.F1RM :_SB_.PCI0.SBRG.EC0_.F1DT :_SB_.SAMB.TMPC :_SB_.SAMB.TMPH :_SB_.STR0._TMP :_SB_.STR1._TMP :_SB_.STR2._TMP :_SB_.STR3._TMP :_SB_.STR4._TMP :_SB_.STR5._TMP :_SB_.STR6._TMP :_SB_.STR7._TMP :CPUT :GPUT :SYST :FANT :BATT : Quote
pyrojoe34 Posted May 23, 2016 Author Posted May 23, 2016 To update, I am now using beta version 5.70.3854 There is no difference pertaining to this post but I thought I'd make the information up-to-date. It also appears that AIDA only finds the CPU fan header and one mobo case fan header, there are two other fan headers on the mobo it doesn't see (CPU and one other header are PWM, the other two are 3-pin). Quote
pyrojoe34 Posted May 26, 2016 Author Posted May 26, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Any ideas? The socket sensor shows up as "Temp #3" in Corsair Link, and "CPU" (within mobo sensors) in HWinfo. Both Link and HWinfo find 3 temp sensors on the mobo, while AIDA only finds one. AIDA also doesn't see one of the fan headers on the mobo that the other two sensors see. Quote
Fiery Posted May 26, 2016 Posted May 26, 2016 The issue will be fixed in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download. Quote
pyrojoe34 Posted May 26, 2016 Author Posted May 26, 2016 The issue will be fixed in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download. Great! Thanks! Quote
Fiery Posted May 30, 2016 Posted May 30, 2016 The above mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Let me know how it works Thanks, Fiery Quote
pyrojoe34 Posted May 31, 2016 Author Posted May 31, 2016 The above mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Let me know how it works Thanks, Fiery Yup, the CPU socket temp shows up as "aux". Awesome, thanks! Quote
