(Feature Request) Add more monitoring options within stability test graphs?
I often use the stability test graphs to monitor things even when not stress testing and thought it'd be nice to be able to monitor some other sensors on the same graphs. Things like GPU usage, RAM and VRAM usage, SSD/HDD read/write speeds, etc.
Basically allowing more tabs to be added and choosing what to monitor to be customized beyond what you're already given. A way to allow us to monitor basically anything AIDA can already read.
We don't have plans to enable that, since you can achieve the same goal by using the SensorPanel:
You can have the System Stability Test and SensorPanel windows open next to each other.
