Temp Threshold auto-Shutoff?
New to the boards. Just registered. Did a search for the term shutoff and couldn't find an answer.
Does AIDA64 support auto shutoff of the computer for set threasholds or just alarms? If it does not support shutoff currently...could you add support? etc etc.
AIDA64 already has an Alerting feature that can shut the system down when certain pre-configured thermal or voltage limits are reached, or when a cooling fan stops. To configure the Alerting feature, start AIDA64 Extreme Edition, and navigate to main menu / File / Preferences / Hardware Monitoring / Alerting.
