Lyapa Posted October 3, 2016 Posted October 3, 2016 I incorrectly show options: Power options CPU Package 0,57 W DIMM 1,68 W Debug Info.txt Quote
Fiery Posted October 3, 2016 Posted October 3, 2016 We've seen such anomaly before, but we haven't yet found the root cause of it So right now there's no fix for it. You can however apply a formula (e.g. a multiplier of 10x or 20x or 100x, etc) on the measured values in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction, if you deem it would help to fix them up. Edit: One possible cause could be that you've disabled SVID in the BIOS Setup. If that's the case, then try to enable it again, and check if it helps about the power measurements. Regards, Fiery Quote
Lyapa Posted October 4, 2016 Author Posted October 4, 2016 Enabling and disabling SVID in the BIOS setup not affect Quote
Fiery Posted October 4, 2016 Posted October 4, 2016 Enabling and disabling SVID in the BIOS setup not affect Then I'm afraid the issue must be due to a CPU pecularity that is currently unknown to us. So I'm unable to help you Quote
