dlnxx1 Posted October 6, 2016 Posted October 6, 2016 AIDA64 engineering latest stable version, no fan speed data. I am able to see my fan speeds in bios, not in AIDA64 Asus P10S-WS Board Any help? Quote
Fiery Posted October 7, 2016 Posted October 7, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
dlnxx1 Posted October 9, 2016 Author Posted October 9, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Please find attached TXT files. 4 fans are installed (3 case, 1 CPU fan) ecdump.txt isasensordump.txt Quote
dlnxx1 Posted October 12, 2016 Author Posted October 12, 2016 Wondering if there is any update after posting the required TXT files? Thanks Quote
Fiery Posted October 18, 2016 Posted October 18, 2016 Thank you for the data. The issue will be fixed in the next AIDA64 beta update due later this week. I'll post a message into this topic once the new beta is available for download. Thank you for your patience 1 Quote
Fiery Posted October 20, 2016 Posted October 20, 2016 The above mentioned new AIDA64 beta update is available for download at: https://www.aida64.com/downloads/latesta64xebeta Please let me know how it works 1 Quote
dlnxx1 Posted October 20, 2016 Author Posted October 20, 2016 9 hours ago, Fiery said: The above mentioned new AIDA64 beta update is available for download at: https://www.aida64.com/downloads/latesta64xebeta Please let me know how it works Works great now! Thank you Fiery Quote
