Radical Redemption Posted November 13, 2016 Posted November 13, 2016 I get these temps while converting a video and the CPU usage is between 70 and 100%. CPU: amd fx 9590 MOBO: asrock fx990 extreme6 Cooler: Kraken x61 Quote
Fiery Posted November 17, 2016 Posted November 17, 2016 "CPU" temperature is measured by the onboard sensor chip (onboard = integrated on the motherboard PCB), while the core temperatures are measured by the CPU itself. Under heavy load both temperatures should be reliable, but at idle many modern AMD processors measure unrealistically low core temperatures (e.g. 0 or 5 Celsius with an ambient temperature of over 20 Celsius). As long as all CPU or CPU related temperatures are below 80 Celsius, you're fine. Quote
