Hello
I have a problem with my Corsair H110i GTX system and Aida64. I installed all actual drivers now if i start aida 64 go to the sensors window my fans from the h110i going to max rpm ?.
I can fix this problem if i close aida and start corsair link software then the fans going to normal mode ?
I ask an friendly guy from the corsair forum but he has no idea.
The aida and corsair software work fine but i reinstalled my pc with an bios update and now i have this problem. I cant believe that is the problem.
Thank you
Regards
Try to set Asetek fan speed to your fan duty cycle % value in AIDA64 / main menu / File / Preferences / Hardware Monitoring.  It should help to avoid the fans ramping up to 100% duty cycle.
