LEMIWINKS Posted March 20, 2017 Posted March 20, 2017 Hi guys, recently got a water temp plug sensor and wanted to know if there's any way Aida can read it over USB if I were to get this thing https://www.google.com.au/search?q=alphacool+heatmaster&oq=alphacool+heat&aqs=chrome.1.69i57j0l3j69i60.10548j0j4&client=ms-android-telstra-au&sourceid=chrome-mobile&ie=UTF-8#imgrc=RkkGAkbfWtJdRM: My board doesn't have a 2 pin temp sensor unfortunately. Cheers for your time Quote
Fiery Posted March 20, 2017 Posted March 20, 2017 Heatmaster II is already supported by AIDA64. Just go to AIDA64 / main menu / File / Preferences / Stability, and enable the option called Heatmaster II sensor support. Make sure to restart AIDA64 after altering that option. Regards, Fiery Quote
