santiagodraco Posted April 11, 2017 Posted April 11, 2017 As the title suggest Aida64 isn't reporting the network connection speed of 10gb nics properly. I'm running the Intel 10GbE Converged Network adapter and the OSD displays 1410 Mbps as the speed when of course it should be 10Gb. 1Gb connections properly report as 1000 Mbps. Thanks Quote
Fiery Posted April 12, 2017 Posted April 12, 2017 On 2017. 04. 11. at 2:21 AM, santiagodraco said: As the title suggest Aida64 isn't reporting the network connection speed of 10gb nics properly. I'm running the Intel 10GbE Converged Network adapter and the OSD displays 1410 Mbps as the speed when of course it should be 10Gb. 1Gb connections properly report as 1000 Mbps. Thanks Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
santiagodraco Posted April 14, 2017 Author Posted April 14, 2017 Will give that a try today. Thanks! Quote
