Displax Posted June 10, 2017 Posted June 10, 2017 I sent you this bug-repoort some time ago by mail ( android-report@aida64.com ), but I do not know if you see it... So, problem in the title - thermal sensor (except the battery) are not displayed on the Nexus 6P running Android 7.1.1 (maybe 7.1.2). On 6.0.1 and 7.0 its OK. I do not check it now (report was sent from v1.42), maybe it is already fixed, but I will be grateful if you check this. Thanks. Quote
Fiery Posted June 11, 2017 Posted June 11, 2017 There's no fix for that I'm afraid. On its Nexus and Pixel devices Google -- for whatever reason -- decided to further limit apps access to certain system directories, like the ones necessary for temperature measurement. So now it's not possible to read any temperatures but the battery temperature. It applies to any apps running on your device, not just AIDA64. 1 Quote
