mito Posted June 16, 2017 Posted June 16, 2017 greetings, are there plans to release an update? thanks! Basic Properties Device iPad7,1 Dock Connector Unknown SIM Card Type Unknown Device String iPad7,1 Device Id J120AP Released Dec 31, 1969 Capabilities Cellular No GPS No NFC No Force Touch No Bluetooth Version Unknown Controller Unknown Bluetooth Smart (LE) No Physical Properties Width 0.0 mm Height 0.0 mm Depth 0.0 mm Weight 0 g CPU Properties CPU Unknown Speed (null) Manufacturer Unknown Instruction Set Unknown Microarchitecture Unknown Technology Unknown Core Count 3 Active Core Count 3 GPU Properties GPU Type Unknown GPU Cores 1 Co-processor Properties Co-processor Unknown Storage Information Device Model 63 GB Total Storage 59.60 GB Available Storage 45.72 GB RAM Information Total RAM 3976 MB Available RAM 189 MB Screen Size Screen Size 0.0" Aspect Ratio Unknown Pixel Density 0 PPI Screen Parameters Vertical Resolution 0 Pixels Horizontal Resolution 0 Pixels Contrast Unknown Brightness 0 cd/m² Technology Unknown Back Camera Resolution Unknown MegaPixels Aperture 0.0 Max Video Resolution Unknown Max Video Speed Optical Stabilization No Max Photo Resolution 4032 x 3024 Shortest Exposure Value 1/500000 sec Longest Exposure Value 1/3 sec Front Camera Resolution Unknown MegaPixels Aperture 0.0 Max Video Resolution Unknown Max Video Speed Unknown Optical Stabilization No Max Photo Resolution 3840 x 2160 Shortest Exposure Value 1/76923 sec Longest Exposure Value 1/2 sec Assigned IP Addresses Wi-Fi (IPv4) 192.168.137.231 Wi-Fi (IPv6) fe80::8ad:63f0:8eab:2664 Cellular (IPv4) Not Available Cellular (IPv6) Not Available Wi-Fi Details SSID erthy560 BSSID e8:cc:18:bb:8:b4 Capabilities Unknown Controller Unknown Battery Status Charging Level 98 % Voltage 0.0 V Capacity 0 mAh Type Li-Ion Polymer Battery Details Charge 10878 / 11100 mAh (98 %) Wear Level 0.00 % Voltage 4.271 V Adapter Details Installed OS Operating System iOS Version 10.3.2 Build Number 14F8089 OS State Stable Multitasking Yes Current Session Active Time 0d 1h 42m Uptime 0d 1h 22m OS Compatibility Initial OS Version Unknown Max Supported OS Version Unknown AIDA64 for iOS Version 1.15 (312) Copyright (c) 2015-2017 FinalWire. All rights reserved. Quote
Mice007 Posted June 16, 2017 Posted June 16, 2017 Hi Of course, an update is scheduled to support new devices very soon. Thanks for the report. 1 Quote
mito Posted June 19, 2017 Author Posted June 19, 2017 it's working now, but the appstore did not update aida64.... how come? Basic Properties Device iPad Pro 2 Dock Connector Lightning SIM Card Type None Device String iPad7,1 Device Id J120AP Released Dec 31, 1969 Capabilities Cellular No GPS No NFC No Force Touch No Bluetooth Version 4.2 Controller Murata/Apple 339S00249 Bluetooth Smart (LE) Yes Physical Properties Width 220.6 mm Height 305.7 mm Depth 6.9 mm Weight 677 g CPU Properties CPU Apple A10X Speed 2380 MHz Manufacturer Instruction Set 64-bit ARMv8-A Microarchitecture Fusion Technology 16 nm Core Count 6 Active Core Count 3 GPU Properties GPU Type PowerVR Series7 GPU Cores 12 Co-processor Properties Co-processor Apple M10 Storage Information Device Model 63 GB Total Storage 59.60 GB Available Storage 41.26 GB RAM Information Total RAM 3976 MB Available RAM 181 MB Screen Size Screen Size 12.9" Aspect Ratio 4:3 Pixel Density 264 PPI Screen Parameters Vertical Resolution 2732 Pixels Horizontal Resolution 2048 Pixels Contrast 1400:1 Brightness 500 cd/m² Technology IPS Back Camera Resolution 12 MegaPixels Aperture 1.8 Max Video Resolution 4k @ 30fps Max Video Speed 240fps @ 720p Optical Stabilization Yes Max Photo Resolution 4032 x 3024 Shortest Exposure Value 1/500000 sec Longest Exposure Value 1/3 sec Front Camera Resolution 7.0 MegaPixels Aperture 2.2 Max Video Resolution 1080p @ 30fps Max Video Speed 30fps @ 1080p Optical Stabilization Electronic Max Photo Resolution 3840 x 2160 Shortest Exposure Value 1/76923 sec Longest Exposure Value 1/2 sec Assigned IP Addresses Wi-Fi (IPv4) 192.168.137.231 Wi-Fi (IPv6) fe80::e0:3d8b:9ef1:331 Cellular (IPv4) Not Available Cellular (IPv6) Not Available Wi-Fi Details SSID ertzzz BSSID e8:cc:18:bb:8:b4 Capabilities 802.11 a/b/g/n/ac Controller Murata/Apple 339S00249 Battery Status Charging Level 100 % Voltage 3.77 V Capacity 10875 mAh Type Li-Ion Polymer Battery Details Charge 11200 / 11200 mAh (100 %) Wear Level 0.00 % Voltage 4.299 V Adapter Details Installed OS Operating System iOS Version 10.3.2 Build Number 14F8089 OS State Stable Multitasking Yes Current Session Active Time 0d 9h 24m Uptime 0d 8h 40m OS Compatibility Initial OS Version iOS 10.3.2 Max Supported OS Version iOS 10+ AIDA64 for iOS Version 1.15 (312) Copyright (c) 2015-2017 FinalWire. All rights reserved. Quote
mito Posted July 4, 2017 Author Posted July 4, 2017 houston, we have a problem. correction: I thought it was extracting correct info, but it isn't. happy new year..... Quote
Mice007 Posted July 5, 2017 Posted July 5, 2017 Thanks, we are about to roll out an update this week, it will solve the above issue and also improve the support for new devices and the upcoming iOS11. 1 Quote
