lamp_art Posted July 14, 2017 Posted July 14, 2017 Hi, I have problem with low RAM write speed on AIDA64 benchmark. My platform is: i5-4690k@4.7 GHz, cache 4.2 GHz Asrock Z87 Extreme3 2x8 GB G. Skill TridentX 2400 CL10 (double sided) Windows 10 Pro Ram is in double channel configuration with XMP profile active. Before TridentX I had Kingston 1333 CL9 sticks. After upgrade I see massive boost in WinRAR benchmark (~4900 kb/s to almost 7200 kb/s), boost in fps in games, faster rendering and video compression. RAM read tests give me almost 36000 MB/s, but RAM write tests give me only ~21500 MB/s. Shouldn't it be much higher? I've tried CPU stock clock setting, manual timings configuration, changing RAM 1T/2T and nothing helped. Motherboard have newest BIOS, Ram are in A2/B2 slots, with slots A1/A2 no difference. Lowering RAM frequency to 2133/1866 impacts on read speed but write speed doesn't change. Quote
Fiery Posted July 17, 2017 Posted July 17, 2017 I think the Memory Write performance is limited by the uncore frequency. In other words: the memory controller simply cannot churn out more data using non-temporal write, even at higher memory frequencies. Quote
