Kermolata Posted October 10, 2017 Share Posted October 10, 2017 So I surfed around the internet but couldn't find an exact answer, so here I am. Is the 80w are total usage of the GPU diode or is it just the core.Do we add VRM's watts to the total power usage? I know the numbers that are monitored are rough. Just want to know if total usage of GPU is close to 80w or 120w. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Fiery Posted October 10, 2017 Share Posted October 10, 2017 On your particular video card those 2 values are measured using different methods, so you definitely shouldn't add those numbers up or combine them in any ways. AMD GPUs use quite a few secret tricks that are not documented well enough -- but AIDA64 uses those tricks to provide every possible measurements. Due to the lack of documentation though, it's hard for us to provide you with guidelines on how to interpret the readings. 1 Quote Link to comment Share on other sites More sharing options...
