Gekido Posted October 27, 2017 Posted October 27, 2017 Hello, With RemoteSensor the text of some sensor are wrong placement on screen. On RemoteSensor settings: And what happens on smartphone: I don't understand. Thank you and sorry I can't speak english well. Quote
Fiery Posted October 27, 2017 Posted October 27, 2017 Such things could happen when the text simply doesn't fit on the screen of the mobile device, and so the browser will wrap the text into multiple lines. Did you configure the right resolution for your browser? Also, I think the font is also incorrect. It could happen when the browser running on the mobile device doesn't support the selected font. In which case you should simply use a different font, like Arial. Quote
Gekido Posted October 28, 2017 Author Posted October 28, 2017 Thank you for reply. Yes this is the right resolution for the browser. I tried with different browser, different font and different device, but it's the same thing. This is my template: And on the device: Thank you. Quote
