sheilaanderson Posted April 6, 2018 Posted April 6, 2018 Hello, I've recently upgraded my old ADSL 6Mbps connections to our towns new optic 150Mbps (168Mbps measured). On my sensor panel the Connections Speed was measured at 7.8 Mbps when I was on DSL but now it doesn't change to reflect the new connection speed. The Graphs I use to measure upload and download work (wish I could measure in MB/s instead of KB/s but I know that's coded and can't be changed) Not sure if it is something I need to change somewhere or is this just a bug. I'm running version 5.75.3940 beta. Thank you. Quote
Fiery Posted April 7, 2018 Posted April 7, 2018 Are you sure the new optic connection uses the same network interface (network adapter) as your old ADSL connection? Make sure to check all network interfaces on the Network / Windows Network page of AIDA64. Quote
