Tekred Posted April 10, 2018 Posted April 10, 2018 First time using Aida64 and for some reason my GPU and HDD temps readouts on the simple sensor item shows TRIAL. i have attached a screenshot to show Quote
an3k Posted April 10, 2018 Posted April 10, 2018 On https://www.aida64.com/downloads you can read the following: Quote Here you can download a free 30-day trial of AIDA64 Extreme and AIDA64 Engineer. During the trial period AIDA64 may offer limited functionality, and may not display all data on the information and benchmark result pages. I assume you haven't bought AIDA64 yet but use the 30-day trial which may not show GPU or HDD temps but TRIAL instead. Quote
Tekred Posted April 10, 2018 Author Posted April 10, 2018 Ok thanks got it figured out thanks to your help, I did purchase it then was completely overwhelmed by it so decided to just keep using nzxt cam so I removed it. Then decided since I paid for it to give it another try so downloaded it again but forgot to activate it lol thank you 1 Quote
an3k Posted April 11, 2018 Posted April 11, 2018 You're welcome. At first use AIDA is too overwhelming to understand it's power but once you played a little bit you see it's way better than other tools, especially because you can configure it how you like it. You want to test OSD Panel or SensorPanel Quote
