I have just migrated from a Goverlay and I am loving the software. I am however having two issues reading the sensors on my USB aquacomputer D5 pump.
Issue 1)
I can only get the temperature probe reading from the aquasuite software to work. The other two readings Pump Power and Speed Signal don't seem to be available. These are the readings I am after from aquasuite.
Issue 1)
Can you please post a screen shot, showing what values are you looking for and how they're measured by aquasuite?
Also, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
BTW,what's issue #2? :)
