fluffi444 Posted September 21, 2018 Posted September 21, 2018 Hey Guys. I updated my AIDA64 to latest official release and my readings (on Logitech G19 Display) showing wrong results. OK - the Northbridge Temp seams to be away in availabe values. But now there is AUX "instead". CPU Temp (not core) shows now the NB temp. AUX is... Don't know. CPU (not core) is not findable anymore. Still on old but gold X58 Chipset: GA-EX58-EXTREME and CPU X5650 Version 5.97.4600 is working and gives correct values. This all was starting with one of the last BETAs. Any Idea or solution? EDIT - 23.09.2018 I enclosed two files - ISA Sensor Dump of latest and of working version isasensordump_X58_5.98.4800_NOT_OK.txt isasensordump_X58_5.97.4600_OK.txt Quote
Fiery Posted September 23, 2018 Posted September 23, 2018 Thank you for the dumps. I'm not sure what's happened, but we'll fix this issue in the next AIDA64 beta due in a few days from now. I'll post a message into this topic once the new beta build is available for download. 1 Quote
Fiery Posted September 25, 2018 Posted September 25, 2018 On 9/21/2018 at 5:08 PM, fluffi444 said: Hey Guys. I updated my AIDA64 to latest official release and my readings (on Logitech G19 Display) showing wrong results. OK - the Northbridge Temp seams to be away in availabe values. But now there is AUX "instead". CPU Temp (not core) shows now the NB temp. AUX is... Don't know. CPU (not core) is not findable anymore. Still on old but gold X58 Chipset: GA-EX58-EXTREME and CPU X5650 Version 5.97.4600 is working and gives correct values. This all was starting with one of the last BETAs. Any Idea or solution? EDIT - 23.09.2018 I enclosed two files - ISA Sensor Dump of latest and of working version isasensordump_X58_5.98.4800_NOT_OK.txt isasensordump_X58_5.97.4600_OK.txt We've fixed the issue in the latest AIDA64 beta update: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. 1 Quote
fluffi444 Posted September 28, 2018 Author Posted September 28, 2018 On 9/25/2018 at 10:03 PM, Fiery said: We've fixed the issue in the latest AIDA64 beta update: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Great! Works! NB temp is back and everything else is good again, too! Thanks for that great support! Quote
Fiery Posted September 28, 2018 Posted September 28, 2018 22 minutes ago, fluffi444 said: Great! Works! NB temp is back and everything else is good again, too! Thanks for that great support! Thank you for your feedback 1 Quote
