GoToEloy Posted September 21, 2018 Posted September 21, 2018 Good afternoon. I have the latest beta version of the aida64 the 5.98.4800 in its notes says that it has support for my model of liquid refrigferacion but I still do not get the sensors of the liquid of the RL or its pump, previously with other older versions and with the H115i if it showed those sensors. Do you know what may have happened? Quote
Fiery Posted September 23, 2018 Posted September 23, 2018 On 9/21/2018 at 7:59 PM, GoToEloy said: Good afternoon. I have the latest beta version of the aida64 the 5.98.4800 in its notes says that it has support for my model of liquid refrigferacion but I still do not get the sensors of the liquid of the RL or its pump, previously with other older versions and with the H115i if it showed those sensors. Do you know what may have happened? Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Corsair Link Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
GoToEloy Posted September 23, 2018 Author Posted September 23, 2018 I attach the TXT files. Thanks for the help corsairlinkdump.txt usbdump.txt Quote
Fiery Posted September 25, 2018 Posted September 25, 2018 On 9/23/2018 at 11:15 PM, GoToEloy said: I attach the TXT files. Thanks for the help corsairlinkdump.txt usbdump.txt Thank you. Make sure to close Corsair's iCUE software and Corsair's Link software before starting AIDA64. Corsair's own monitoring software is not designed to work well with 3rd party monitoring software running the same time. Also, make sure that you have Asetek LC sensor support enabled (checked) in AIDA64 / main menu / File / Preferences / Stability. Quote
GoToEloy Posted September 25, 2018 Author Posted September 25, 2018 I have activated that sensor and I first open aida before the icue software and nothing. In previous versions if I showed the speed of the pump and the temperature of the coolant but when switching to the new H115i pro they stopped seeing each other. Quote
GoToEloy Posted September 28, 2018 Author Posted September 28, 2018 still does not work even uninstalling the Icue Quote
Fiery Posted October 2, 2018 Posted October 2, 2018 On 9/28/2018 at 7:12 PM, GoToEloy said: still does not work even uninstalling the Icue Please copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic, or create a screen shot of that page. Quote
GoToEloy Posted October 2, 2018 Author Posted October 2, 2018 I do not know if it refers to this. Report.txt Quote
Fiery Posted October 3, 2018 Posted October 3, 2018 13 hours ago, GoToEloy said: I do not know if it refers to this. Report.txt Thank you. I think the issue is that you don't have the necessary SiUSBXp.dll library installed on your system, or AIDA64 is unable to locate it. Can you please try to find that file on your system, and let us know the full path name for the file? Quote
GoToEloy Posted October 3, 2018 Author Posted October 3, 2018 9 hours ago, Fiery said: Gracias. Creo que el problema es que no tiene instalada la biblioteca SiUSBXp.dll necesaria en su sistema, o AIDA64 no puede encontrarla. ¿Puede intentar encontrar ese archivo en su sistema y darnos el nombre completo de la ruta para el archivo? F:\Corsair\CORSAIR iCUE Software Quote
Fiery Posted October 5, 2018 Posted October 5, 2018 On 10/3/2018 at 11:07 PM, GoToEloy said: F:\Corsair\CORSAIR iCUE Software Thank you. Please check the latest AIDA64 beta: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
GoToEloy Posted October 5, 2018 Author Posted October 5, 2018 Thank you very much for the new update, now if you see the speed of the fans of the liquid refrigeration, the water pump and the temperature of the coolant. So it's nice that they attend to the problems that arise. thank you very much. PS: sometimes N / A comes out at the temperature of the liquid, it seems that it is not stable. Quote
Fiery Posted October 8, 2018 Posted October 8, 2018 On 10/5/2018 at 11:19 PM, GoToEloy said: Thank you very much for the new update, now if you see the speed of the fans of the liquid refrigeration, the water pump and the temperature of the coolant. So it's nice that they attend to the problems that arise. thank you very much. PS: sometimes N / A comes out at the temperature of the liquid, it seems that it is not stable. Thank you for your feedback. When the liquid temperature reading becomes unstable, do the other readings (fan RPM, pump RPM) also become unstable? Or it's only the liquid temperature that has that issue? Quote
GoToEloy Posted October 8, 2018 Author Posted October 8, 2018 all related to liquid cooling corsair, RPM fans, pump and liquid Quote
Fiery Posted October 29, 2018 Posted October 29, 2018 On 10/8/2018 at 10:01 PM, GoToEloy said: all related to liquid cooling corsair, RPM fans, pump and liquid We've tweaked device opening on Corsair H115i Pro to make it work more stable with your system. Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works on your system. Quote
GoToEloy Posted November 2, 2018 Author Posted November 2, 2018 OK. I will be attentive to the measurements to tell you any anomaly. Thanks for your work Quote
GoToEloy Posted November 28, 2018 Author Posted November 28, 2018 ---------------Detectar idiomaAfrikáansAlbanésAlemánAmáricoÁrabeArmenioAzerbaiyanoBengalíBielorrusoBirmanoBosnioBúlgaroCanarésCatalánCebuanoChecoChino (simplificado)Chino (tradicional)CingalésCoreanoCorsoCriollo haitianoCroataDanésEslovacoEslovenoEspañolEsperantoEstonioEuskeraFinésFrancésFrisón occidentalGaélico escocésGalésGallegoGeorgianoGriegoGuyaratíHausaHawaianoHebreoHindiHmongHúngaroIgboIndonesioInglésIrlandésIslandésItalianoJaponésJavanésJemerKazajoKirguísKurdoLaoLatínLetónLituanoLuxemburguésMacedonioMalayalamMalayoMalgacheMaltésMaoríMaratíMongolNeerlandésNepalíNoruegoNyanjaPanyabíPastúnPersaPolacoPortuguésRumanoRusoSamoanoSerbioShonaSindhiSomalíSotho meridionalSuajiliSuecoSundanésTagaloTailandésTamilTayikoTeluguTurcoUcranianoUrduUzbekoVietnamitaXhosaYidisYorubaZulúEspañol good afternoon. I have updated the Aida64 to version 5.99.4900 and the cooling sensor has stopped working Quote
Fiery Posted November 28, 2018 Posted November 28, 2018 12 minutes ago, GoToEloy said: ---------------Detectar idiomaAfrikáansAlbanésAlemánAmáricoÁrabeArmenioAzerbaiyanoBengalíBielorrusoBirmanoBosnioBúlgaroCanarésCatalánCebuanoChecoChino (simplificado)Chino (tradicional)CingalésCoreanoCorsoCriollo haitianoCroataDanésEslovacoEslovenoEspañolEsperantoEstonioEuskeraFinésFrancésFrisón occidentalGaélico escocésGalésGallegoGeorgianoGriegoGuyaratíHausaHawaianoHebreoHindiHmongHúngaroIgboIndonesioInglésIrlandésIslandésItalianoJaponésJavanésJemerKazajoKirguísKurdoLaoLatínLetónLituanoLuxemburguésMacedonioMalayalamMalayoMalgacheMaltésMaoríMaratíMongolNeerlandésNepalíNoruegoNyanjaPanyabíPastúnPersaPolacoPortuguésRumanoRusoSamoanoSerbioShonaSindhiSomalíSotho meridionalSuajiliSuecoSundanésTagaloTailandésTamilTayikoTeluguTurcoUcranianoUrduUzbekoVietnamitaXhosaYidisYorubaZulúEspaño good afternoon. I have updated the Aida64 to version 5.99.4900 and the cooling sensor has stopped working Please send us an updated Corsair Link Dump and USB Dump, using AIDA64 v5.99.4900. Quote
GoToEloy Posted November 28, 2018 Author Posted November 28, 2018 corsairlinkdump.txt usbdump.txt Quote
GoToEloy Posted November 28, 2018 Author Posted November 28, 2018 it has returned to work from nothing Quote
Fiery Posted December 1, 2018 Posted December 1, 2018 On 11/28/2018 at 9:22 PM, GoToEloy said: it has returned to work from nothing Do you have other monitoring software installed? Maybe it was a collision between that software and AIDA64. Quote
