2 hours ago, Alex Dudek said:
Hi I have a simple question. How can I export the settings or configuration of AIDA64?
Of course including the opcions of its gadget.
Thanks, and sorry for my English.
Exporting and importing settings is easy: just backup the file called AIDA64.INI that you can find in the AIDA64 installation folder.
16 hours ago, Mayo0666 said:
But will it export also the new gauges i created or should I back up them too?
AIDA64 manages custom gauges as external files, so you should back them up too.
