fixed: CPU & mainboard sensor temperature always shows the same (Alienware X51 R3)
3 hours ago, iamyangyi said:
Question submission:
ALIENWARE X51 R3 cpu&mainboard Sensor temperature always shows the same, CPU always 30 °C,Mainboard always 28 °C
AIDA64  & beta the version is the latset
7 hours ago, Fiery said:
Thank you.  Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works.
THX, The new test version of CPU & motherboard temperature shows that the change, it seems normal.but the motherboard temperature sensor has become four, one temperature is particularly high。
Thank you for your feedback.  What you can see is normal.  The NCT6683D sensor chip that is integrated on your motherboard is capable of measuring 5 different temperatures.  Unfortunately only Alienware (Dell) knows what the 4 generic motherboard temperature readouts stand for.  Or maybe you can find the thermal readings in the BIOS Setup as well?
