dwdallam Posted July 21, 2011 Posted July 21, 2011 When I tried to add a bar graph to CPU activity the panel locked. I deleted everything and now when I right click, it locks up. There is now no way to initiate and configure Sensor Panel. System: DMI BIOS Vendor Award Software International, Inc. DMI BIOS Version FA DMI System Manufacturer Gigabyte Technology Co., Ltd. DMI System Product X58A-UD5 CPU Type QuadCore Intel Core i7-920, 3800 MHz (21 x 181) Motherboard Name Gigabyte GA-X58A-UD5 v2 (1 PCI, 2 PCI-E x1, 4 PCI-E x16, 6 DDR3 DIMM, Audio, Dual Gigabit LAN, IEEE-1394) Motherboard Chipset Intel Tylersburg X58, Intel Nehalem Quote
Fiery Posted July 21, 2011 Posted July 21, 2011 1) First of all, make sure to have the latest AIDA64 beta release: http://www.aida64.com/downloads/aida64extremebuild1481xz1wg0rpkvzip 2) Do you get a lockup with the OSD Panel feature as well? Or on the Computer / Sensor page? 3) You can reset the SensorPanel feature into its default state by editing the AIDA64.INI file that you can find in the AIDA64 installation folder. From the AIDA64.INI file make sure to remove any lines starting with HWMonSP Or you can even remove the AIDA64.INI file completely, if you don't have any other AIDA64 settings you want to retain. Regards, Fiery Quote
dwdallam Posted July 27, 2011 Author Posted July 27, 2011 That reset it and I have it back now. Thank you. Quote
