SverreMunthe Posted December 19, 2018 Posted December 19, 2018 I just bought Corsair Hydro H150i for my MediaServer and found that what Aida64 is reporting as fan speed is what Corsair Link reports as pump speed. The 3 fans connected to the Corsair Hydro H150i doesn't seem to get detected by Aida64. Is there a workaround for this? Quote
Fiery Posted December 20, 2018 Posted December 20, 2018 23 hours ago, SverreMunthe said: I just bought Corsair Hydro H150i for my MediaServer and found that what Aida64 is reporting as fan speed is what Corsair Link reports as pump speed. The 3 fans connected to the Corsair Hydro H150i doesn't seem to get detected by Aida64. Is there a workaround for this? Make sure to have Asetek LC sensor support enabled in AIDA64 / main menu / File / Preferences / Stability, and that you've got your H150i device connected to one of the USB ports or USB headers of the motherboard. Quote
