Hello all,
I just received a new build from NZKT. I decided to run your stress test, as I am getting little issues here and there.
I am receiving super hot temps at default levels in a short time. No overclocking.I had all the tests running and my computer basically locked up, sporadic movement with the mouse, I had trouble stopping the test.  See picture attached below
Here are my system Specs:
i9 9900k, NZXT Kraken X62 Cooler, ASUS Maximus XI (Wifi), 32GB GSkill RGB (8gx4)DDR4 3600mhz, NVME Samsung 970 1tb, 3 x 140m Case Fans, NZKT H700i Case
Thanks for the help
As long as the bottom graph (in AIDA64 System Stability Test) doesn't show any throttling activity for your CPU under heavy load, you have nothing to worry about.
