M.2 temperature (AData XPG Gammix S11 - ASRock AB350 Pro4)
On ‎12‎/‎29‎/‎2018 at 4:25 PM, silicone said:
After update bios Asrock AB350 Pro 4, AIDA don't read temperature of m.2 ADATA  XPG GAMMIX S11. How can I resolve this ?  Thank you
Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
On ‎12‎/‎30‎/‎2018 at 9:29 PM, silicone said:
Thank you for the data.  I think the issue is because of AMD SATA/NVMe/RAID chipset drivers causing the classic NVMe SMART functions stop working.  We'll work on it, although I'm not entirely sure if there's a proper way to get around this issue :(
