I could not find any description on how or where to install a beta version on a system with the latest AIDA64 Extreme (licensed, not trial).  Do I unzip the beta version and copy it into the non-beta AIDA64 folder?
Yes.  Upgrading to a new beta is as simple as that.  You can let it overwrite any existing files.  It will retain your existing settings (it won't overwrite or remove AIDA64.INI file) as well as your existing license.
