Snuk Posted February 4, 2019 Posted February 4, 2019 Hello, I have a new build with: Procesor: i5 9600k MB: Asus Z370-P II Memory: 2x Corsair LPX 8GB DDR4 3000Mhz CL16 Power Suply: Seasonic Focus 650W GPU: RTX 2060 My problem is when I set XMP to boost my RAM to 3000Mhz, AIDA64 says "Hardware failure" only on "System memory test". I run AiDA64 for CPU, FSU and memory cache and run great. I run Prime95 (no errors), Realbench (no errors), HCI memtest(no errors), MemTest86(no errors)... What could make my ram to do hardware failure on AIDA64? When i go stock to 2133Mhz AIDA64 is not showing anymore that hardware failure... Quote
Fiery Posted February 4, 2019 Posted February 4, 2019 1 hour ago, Snuk said: Hello, I have a new build with: Procesor: i5 9600k MB: Asus Z370-P II Memory: 2x Corsair LPX 8GB DDR4 3000Mhz CL16 Power Suply: Seasonic Focus 650W GPU: RTX 2060 My problem is when I set XMP to boost my RAM to 3000Mhz, AIDA64 says "Hardware failure" only on "System memory test". I run AiDA64 for CPU, FSU and memory cache and run great. I run Prime95 (no errors), Realbench (no errors), HCI memtest(no errors), MemTest86(no errors)... What could make my ram to do hardware failure on AIDA64? When i go stock to 2133Mhz AIDA64 is not showing anymore that hardware failure... It means your system memory is not stable at 3000 MHz setting. You can try to fine-tune the memory timings or adjust the memory voltage to make it stable. Quote
