fixed: Fan speed sensors don't work (ASRock Z370M Pro4)
On ‎2‎/‎6‎/‎2019 at 8:01 PM, letschky said:
Hi,
i have an  ASRock Z370M Pro4 Mainboard,GPU Fan Speed works,but the Cpu,Waterpump,Casefans will not be shown.
So far it has worked for every Asrock board.
Thanks
smbusdump_full.txt
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Hi,
thanks for the answer.
Here the ISA Sensor Dump
isasensordump.txt
