Garretts_studio Posted April 29, 2019 Posted April 29, 2019 I have an i7 6950X Asus X99 M WS mATX Motherboard and I can see the temps in Bios and other programs like the Task Manager, MSI Afterburner with no problems but for some reason in AIDA64 they stopped showing up even in preferences they just show a sand timer next to the check boxes and also I know it hasn't been working for a while and I did try reinstalling AIDA64 for when i first noticed but it didn't fix the issue! Maybe I should try uninstalling and reinstalling again? What else is there I can do to try and fix this problem? Quote
Fiery Posted April 30, 2019 Posted April 30, 2019 On 4/29/2019 at 8:56 PM, Garretts_studio said: I have an i7 6950X Asus X99 M WS mATX Motherboard and I can see the temps in Bios and other programs like the Task Manager, MSI Afterburner with no problems but for some reason in AIDA64 they stopped showing up even in preferences they just show a sand timer next to the check boxes and also I know it hasn't been working for a while and I did try reinstalling AIDA64 for when i first noticed but it didn't fix the issue! Maybe I should try uninstalling and reinstalling again? What else is there I can do to try and fix this problem? Expand Try to uninstall AIDA64, and install the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it makes a difference. Quote
Garretts_studio Posted May 1, 2019 Author Posted May 1, 2019 On 4/30/2019 at 8:11 AM, Fiery said: Try to uninstall AIDA64, and install the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know if it makes a difference. Expand On 5/1/2019 at 11:06 PM, Garretts_studio said: Ok I will Expand Yes it did solve the issue and is now showing up fine. Quote
Fiery Posted May 2, 2019 Posted May 2, 2019 On 5/1/2019 at 11:15 PM, Garretts_studio said: Yes it did solve the issue and is now showing up fine. Expand Awesome! Quote
