Yemble Posted May 5, 2019 Posted May 5, 2019 AIDA OSD panel cannot currently be locked on the desktop, which is a PITA. Why not implement a click-through option, exactly like Rainmeter, whereby mouse clicks are effectively ignored by the OSD, effectively locking it in place? In Rainmeter, CRTL/right-click displays the context menu of the gadget. Ref. screenshot, Rainmeter gadgets on right cannot be accidentally dragged, whereas AIDA OSD can. Quote
Fiery Posted May 7, 2019 Posted May 7, 2019 On 5/5/2019 at 4:25 PM, Yemble said: AIDA OSD panel cannot currently be locked on the desktop, which is a PITA. Why not implement a click-through option, exactly like Rainmeter, whereby mouse clicks are effectively ignored by the OSD, effectively locking it in place? In Rainmeter, CRTL/right-click displays the context menu of the gadget. Ref. screenshot, Rainmeter gadgets on right cannot be accidentally dragged, whereas AIDA OSD can. OSD Panel is supposed to be a quick & easy solution to display sensor readings. If you need a more advanced solution, try AIDA64 SensorPanel which -- among many other things -- supports locking its position and window size. Quote
Yemble Posted May 8, 2019 Author Posted May 8, 2019 23 hours ago, Fiery said: OSD Panel is supposed to be a quick & easy solution to display sensor readings. If you need a more advanced solution, try AIDA64 SensorPanel which -- among many other things -- supports locking its position and window size. A disappointing response really. Quick and simple is exactly what I want and SensorPanel is anything but, which is why I am using the OSD. For me, OSD is the superior of the two options. Given that you have gone to the trouble of developing the OSD in the first place, why not complete the job and allow it to be locked on the screen... or is this too much like rocket science? Quote
Fiery Posted May 8, 2019 Posted May 8, 2019 21 minutes ago, Yemble said: A disappointing response really. Quick and simple is exactly what I want and SensorPanel is anything but, which is why I am using the OSD. For me, OSD is the superior of the two options. Given that you have gone to the trouble of developing the OSD in the first place, why not complete the job and allow it to be locked on the screen... or is this too much like rocket science? Please avoid being arrogant with us on this forum. Please also try to enable the SensorPanel, and check if the Lock panel position option works the way you expect (but for the OSD Panel). If yes, then we can implement that behavior for the OSD Panel as well. Quote
Yemble Posted May 9, 2019 Author Posted May 9, 2019 22 hours ago, Fiery said: Please avoid being arrogant with us on this forum. Please also try to enable the SensorPanel, and check if the Lock panel position option works the way you expect (but for the OSD Panel). If yes, then we can implement that behavior for the OSD Panel as well. Yep, that's all I'm requesting. Quote
Fiery Posted May 9, 2019 Posted May 9, 2019 31 minutes ago, Yemble said: Yep, that's all I'm requesting. It will be implemented in the next AIDA64 beta update. Quote
Yemble Posted May 9, 2019 Author Posted May 9, 2019 23 minutes ago, Fiery said: It will be implemented in the next AIDA64 beta update. Perfect Quote
Fiery Posted July 25, 2019 Posted July 25, 2019 On 5/22/2019 at 7:55 PM, Yemble said: Works as expected in 6.00.5100. Cheers Thank you for your feedback Quote
