Renesas ISL69138 Controller VR VOUT (ASRock Z370 Extreme4)
Globespy
Hello
Does Ada64 measure this sensor.
AsRock Z370 Extreme 4
BIOS 3.10 (no need to update since I don't have 9 series CPU)
i7 8086K - purchased from 'silicon lottery' hand picked 'delidded' 5.3GHz at 1.4v all cores, no AVX.
vCore is 1.395v fixed in BIOS, LLC1, all power states disabled, Speedshift and Speedstep disabled also - this is a gaming rig so I have little need for power savings.
Win 10 1903 RTM running 'Ultimate' performance power plan.
Attaching 3 images for you to pass along to your engineers, taken from HWInfo64 app.
One image is PC at idle on desktop, another under full load in Realbench of, and one showing what I am pretty sure is the VRM/MOSFET's temperatures.
I have highlighted the areas I'm referring to in the images
12 hours ago, Globespy said:
Hello
I'm afraid we don't have any information on that Renesas chip, and it doesn't seem to be compatible with older PWM chips.  We'll need to get the datasheet of that chip to implement support for it.
