Guest Posted May 9, 2019 Posted May 9, 2019 1. Right click status bar and make a dump, like Disk Debug -> Smart Dump. 2. Create a new folder somewhere using the browse dialog, and save the file there. 3. Close the dump window, try to delete the newly created folder via Windows Explorer. 4. The action can't be completed because the folder or a file in it is open in another program. Closing AIDA64 makes deletion possible. Quote
Fiery Posted May 9, 2019 Posted May 9, 2019 7 hours ago, bbent67888 said: 1. Right click status bar and make a dump, like Disk Debug -> Smart Dump. 2. Create a new folder somewhere using the browse dialog, and save the file there. 3. Close the dump window, try to delete the newly created folder via Windows Explorer. 4. The action can't be completed because the folder or a file in it is open in another program. Closing AIDA64 makes deletion possible. I'm afraid we cannot find the reason why AIDA64 holds lock on such folders. We've implemented a more modern save file dialog to the debug dump window, but it works the same about holding the lock. Quote
