vidalsh68 Posted August 3, 2019 Posted August 3, 2019 Max. CPU temps are very powerfull and it´s one of the few little things I miss on aida64. Could be possible that in a near time? thanks Quote
Fiery Posted August 5, 2019 Posted August 5, 2019 On 8/3/2019 at 1:41 PM, vidalsh68 said: Max. CPU temps are very powerfull and it´s one of the few little things I miss on aida64. Could be possible that in a near time? thanks You can monitor minimum and maximum temperatures using the Statistics tab of the AIDA64 System Stability Test module or its Logging facility (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging). 1 Quote
vidalsh68 Posted August 9, 2019 Author Posted August 9, 2019 thanks you. By the way, do you know if max. temperature value can be displayed into sensor panel? Thanks. Quote
Fiery Posted August 13, 2019 Posted August 13, 2019 On 8/9/2019 at 2:17 PM, vidalsh68 said: thanks you. By the way, do you know if max. temperature value can be displayed into sensor panel? Thanks. No, it's not possible to display minimum or maximum temperatures on the SensorPanel. Quote
