Mohammednt0 Posted August 22, 2019 Posted August 22, 2019 i want to display the sensor panel & OSD Panel only on the second desktop (one monitor - 2 desktops) windows 10 has multi-desktops feature (Task View Feature) , when i enable sensor panel & OSD Panel both panels will appear in every desktop i create which is annoying I want to lock them in desktop 2 so when ever i want to check the panels i will just slide to desktop 2, is this possible ? if not will you add this option in the future ? Regards, Quote
Fiery Posted August 24, 2019 Posted August 24, 2019 On 8/22/2019 at 11:33 AM, Mohammednt0 said: i want to display the sensor panel & OSD Panel only on the second desktop (one monitor - 2 desktops) windows 10 has multi-desktops feature (Task View Feature) , when i enable sensor panel & OSD Panel both panels will appear in every desktop i create which is annoying I want to lock them in desktop 2 so when ever i want to check the panels i will just slide to desktop 2, is this possible ? if not will you add this option in the future ? Regards, I'm not sure if it's possible. We will check it. Quote
Mohammednt0 Posted August 26, 2019 Author Posted August 26, 2019 Good Day, thanks for your reply, please update this topic as soon as you figure it out, i will be waiting, thanks a lot Quote
Fiery Posted September 3, 2019 Posted September 3, 2019 On 8/28/2019 at 1:11 PM, Mohammednt0 said: any updates ! We haven't found a solution yet. Quote
Mohammednt0 Posted September 3, 2019 Author Posted September 3, 2019 thanks for your reply, i will be waiting for any updates, thanks again Quote
Fiery Posted October 7, 2019 Posted October 7, 2019 On 10/3/2019 at 8:53 AM, Mohammednt0 said: any updates, is it possible ? I'm afraid we cannot find a solution Quote
