DomDom77 Posted September 6, 2011 Posted September 6, 2011 Hi there,i have a Problem with Aida64 and my CPU Amd Phenom II X4 965 Black Edition. There is NO CPU Temperature and no Core´s Temperature ( 0 C° ) the CPU Temperature line isnt shown :-( What can it be? or is it an other Problem without Aida64? Best Regards :-) Quote
Fiery Posted September 6, 2011 Posted September 6, 2011 Zero core temperatures are normal on systems where ACC is enabled. ACC is usually enabled to unlock the disabled cores of AMD processors. Due to a hardware limitation, core temperatures cannot be measures when ACC is active. As for the "CPU" temperature, we'll need two dumps to check what's wrong with that: 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. Thanks, Fiery Quote
DomDom77 Posted September 6, 2011 Author Posted September 6, 2011 here are the copied things for you : ------[ AIDA64 v1.85.1600 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-2105-000001-00101111-072310-RS785_SB710$A1392001_BIOS DATE: 07/23/10 17:10:34 VER: 21.05 Motherboard Model : Asus M4A785TD-V Evo Motherboard Chipset : AMD 785G, AMD K10 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : M4A785TD-V EVO DMI MB Version : Rev X.0x DMI MB Serial : MT709CK01702160 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2105 ITE 87xx Port = 2Eh ITE 87xx HWMonitor Port = 0290h ITE 87xx Device ID = 8712h ITE 87xx Version = 08h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = FFFFh Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 19 00 FF 03 00 00 00 00 00 80 40 09 07 32 F2 FF 0010 FF FF FF 77 87 7F 7F 7F 01 01 FF FF FF FF FF FF 0020 58 FF D4 FB C5 62 FF FF CC 26 26 80 DD F4 F4 F4 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF 7F FF FF FF 2D FF FF FF FF FF FF FF 0050 35 18 7F 7F 7F 00 56 56 90 56 FD 12 80 00 00 00 0060 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF 0070 7F 7F 7F 00 00 7F FF FF FF FF FF FF FF FF FF FF 0080 00 00 00 00 FF FF FF FF 00 00 FF C0 02 00 99 99 0090 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF 00A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0029 002A 002B T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 T: 38 38 128 Reg$20 CPU Core: r = 88, r*0.016 = 1.41 Reg$21 CPU Aux: r = 255, r*0.016 = 4.08 Reg$22 +3.3 V: r = 212, r*0.016 = 3.39 Reg$23 +5 V: r = 251, r*0.016 = 4.02 Reg$24 +12 V: r = 197, r*0.016 = 3.15 Reg$25 -12 V: r = 98, r*0.016 = 1.57 Reg$26 -5 V: r = 255, r*0.016 = 4.08 ------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 FF FF FF 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 51 F0 F8 F1 F0 F4 F0 70 00 EC FD FD C0 F0 F0 F0 00F0 B0 22 F0 00 80 00 00 20 E2 F0 10 FF FF FF FF FF Reg$59VIN0: r = $0000, r*0.000046 = 0.0000 Reg$5DVIN1: r = $0000, r*0.000046 = 0.0000 Reg$61VIN2: r = $0000, r*0.000046 = 0.0000 Reg$65VIN3: r = $0000, r*0.000046 = 0.0000 Reg$69VIN4: r = $0000, r*0.000046 = 0.0000 Reg$6DVIN5: r = $0000, r*0.000046 = 0.0000 Reg$71VIN6: r = $0000, r*0.000046 = 0.0000 Reg$75VIN7: r = $0000, r*0.000046 = 0.0000 ------[ SB7xx/8xx/9xx PM at 0CD6 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 43 0C 00 0010 6B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 08 04 08 08 08 10 08 20 08 B0 00 00 FE B8 00 0030 00 00 00 00 00 00 00 04 00 00 00 00 00 00 01 FF 0040 00 00 50 9E 00 02 00 00 00 00 00 00 00 00 00 00 0050 E0 05 82 40 00 27 00 05 0C 08 00 00 00 00 00 00 0060 20 48 00 05 02 B4 20 06 8C 03 00 00 F0 00 C0 FE 0070 00 00 0B 80 00 C1 FF FF FF FB 00 00 1F 02 00 00 0080 06 21 43 55 5B 02 00 00 10 10 90 01 00 11 00 20 0090 00 FF 7F 00 1C 06 00 00 00 00 B6 00 00 00 D0 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 2B 50 D1 00 00 00 00 00 00 00 88 40 00 00 00 00 00C0 00 00 00 AA 55 55 55 00 00 01 00 60 00 00 00 00 00D0 00 00 00 00 40 00 00 E3 00 00 00 00 00 00 00 00 00E0 00 17 28 00 00 17 28 00 00 17 28 00 00 17 28 00 00F0 00 17 28 00 00 17 28 00 00 17 28 00 00 17 28 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: M4A785T-V EVO ICPU/VCPU/PCPU: 15372 / 0 / 27239 CPU Temperature : 38.0 C MB Temperature : 38.0 C CHASSIS FAN Speed : 1355 RPM CPU FAN Speed : 2205 RPM POWER FAN Speed : 0 RPM +12 Voltage : 11.916 V +3.3 Voltage : 3.328 V +5 Voltage : 5.017 V Vcore Voltage : 1.408 V CPU Temperature : 38.0 C MB Temperature : 38.0 C Chassis Fan Speed : 1355 RPM CPU Fan Speed : 2205 RPM Power Fan Speed : 0 RPM +12V Voltage : 11.916 V +3.3V Voltage : 3.328 V +5V Voltage : 5.017 V Vcore Voltage : 1.408 V CPU Voltage : 1.45000 V CPU/NB Voltage : 1.10000 V DRAM Voltage : 1.590 V GPU Sideport Voltage : 1.500 V HT Voltage : 1.200 V NB Voltage : 1.100 V SB Voltage : 1.200 V VDDA Voltage : 2.500 V CPU Frequency : 200.00 MHz GPU Frequency : 500.00 MHz GPU Sideport Frequency: 1333.00 MHz CPU Ratio : 17.0x ---------------------------------------- ------[ AIDA64 v1.85.1600 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-2105-000001-00101111-072310-RS785_SB710$A1392001_BIOS DATE: 07/23/10 17:10:34 VER: 21.05 Motherboard Model : Asus M4A785TD-V Evo Motherboard Chipset : AMD 785G, AMD K10 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : M4A785TD-V EVO DMI MB Version : Rev X.0x DMI MB Serial : MT709CK01702160 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2105 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI SMBus Port : 0B00 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D20 ]------ 0000 93 19 24 2E 00 00 00 00 00 00 10 10 10 10 14 88 ..$............. 0010 3D 00 00 00 0A 0A 29 A4 E0 FF AE A4 B3 00 0C 01 =.....)......... 0020 01 01 01 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF 27 09 FF FF 09 FF FF FF FF FF FF FF FF FF FF .'.............. 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D20 ]------ 0000 1993 2419 2E24 002E 0000 0000 0000 0000 0000 1000 1010 1010 1010 1210 8816 3D88 0010 003D 0000 0000 0A00 0A0A 2A0A A429 E0A4 FFE0 AEFF A4AE B3A4 00B3 0C00 010C FF01 0020 FF01 FF01 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF 0927 FF09 FFFF FFFF FF09 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D38 ]------ 0000 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0010 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0020 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0030 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0040 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0050 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0060 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0070 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0080 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 0090 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00A0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00B0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00C0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00D0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00E0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... 00F0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|... ------[ SMBus Device B00-D38 ]------ 0000 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0010 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0020 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0030 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0040 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0050 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0060 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0070 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0080 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 0090 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00A0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00B0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00C0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00D0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00E0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 00F0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100 ------[ SMBus Device B00-D50 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 10 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 2F 41 ............../A 0080 43 4D 58 34 47 58 33 4D 32 41 31 36 30 30 43 39 CMX4GX3M2A1600C9 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 5A 24 00 5A 5A .J.......-.Z$.ZZ 00C0 5A 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Zx...>.p.<<.,<.. 00D0 10 00 23 00 00 00 00 00 00 00 00 00 00 00 00 00 ..#............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D51 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 10 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 2F 41 ............../A 0080 43 4D 58 34 47 58 33 4D 32 41 31 36 30 30 43 39 CMX4GX3M2A1600C9 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 5A 24 00 5A 5A .J.......-.Z$.ZZ 00C0 5A 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Zx...>.p.<<.,<.. 00D0 10 00 23 00 00 00 00 00 00 00 00 00 00 00 00 00 ..#............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 10 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 2F 41 ............../A 0080 43 4D 58 34 47 58 33 4D 32 41 31 36 30 30 43 39 CMX4GX3M2A1600C9 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 5A 24 00 5A 5A .J.......-.Z$.ZZ 00C0 5A 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Zx...>.p.<<.,<.. 00D0 10 00 23 00 00 00 00 00 00 00 00 00 00 00 00 00 ..#............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D53 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 10 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 00 00 00 00 00 00 2F 41 ............../A 0080 43 4D 58 34 47 58 33 4D 32 41 31 36 30 30 43 39 CMX4GX3M2A1600C9 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 5A 24 00 5A 5A .J.......-.Z$.ZZ 00C0 5A 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Zx...>.p.<<.,<.. 00D0 10 00 23 00 00 00 00 00 00 00 00 00 00 00 00 00 ..#............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ Chips Found ]------ B00-D51: SPD B00-D52: SPD B00-D53: SPD Thanks for your help :-) Best Regards Quote
DomDom77 Posted September 7, 2011 Author Posted September 7, 2011 but,there it show´s the CPU Temperature ? but not in the Display under sensor´s . i´m confused. Quote
DomDom77 Posted September 8, 2011 Author Posted September 8, 2011 hi,you have an answer for this? Best Regards. Quote
Fiery Posted September 8, 2011 Posted September 8, 2011 The sensor readings will be fixed in the very next beta release of AIDA64 due next week. It will clear up the temperature labelling issue I'll post a message into this topic once the new beta is available. Quote
Fiery Posted September 12, 2011 Posted September 12, 2011 We've fixed the sensor info in the following new beta version of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild1625bd4flk0yznzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
DomDom77 Posted September 13, 2011 Author Posted September 13, 2011 now the Cpu Temperature is shown,but the Core´s Temperature is as the same before on 0 C° . Best Regards Quote
Fiery Posted September 14, 2011 Posted September 14, 2011 now the Cpu Temperature is shown,but the Core´s Temperature is as the same before on 0 C° . Thanks for the feedback. As I wrote above: Zero core temperatures are normal on systems where ACC is enabled. ACC is usually enabled to unlock the disabled cores of AMD processors. Due to a hardware limitation, core temperatures cannot be measures when ACC is active. Quote
