FoxMulderACF Posted September 17, 2011 Posted September 17, 2011 I'm also having problems with reading the temperature of my processor. I have a Core i7 in a motherboard ASUS P6T Deluxe, and using both the latest stable version as the last beta, reading the processor temperature is different from reading from ASUS Probe II In AIDA64: CPU 29ºC In ASUS Probe II: CPU 47ºC Other readings are correct, only the processor is different. Note: after opening the asus probe, the reading of AIDA64 comes to be correct, being equal to the asus probe, even after closing it. Bug? Best regards, Alexandre I open "AIDA64 main window --> Sensor Debug --> ISA Sensor Dump", see below: ------[ AIDA64 v1.85.1630 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 65-2209-000001-00101111-092110-TYLERSBURG$A1087001_BIOS DATE: 09/21/10 09:24:56 VER: 08.00.15 Motherboard Model : Asus P6T Deluxe Motherboard Chipset : Intel Tylersburg X58, Intel Nehalem DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : P6T DELUXE DMI MB Version : Rev 1.xx DMI MB Serial : MS1C91BJ8T01460 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2209 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port = 0290h Winbond SuperIO Device ID = A513h Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 04 FF 04 FF 00 00 3C 20 01 9B 01 01 3C 3C 04 04 0010 04 FF 30 00 00 01 01 3C 43 17 00 00 2E FF FF C1 0020 84 D8 CF CD D0 FF B7 2D 1F 2A 7C DA 00 10 1A 02 0030 02 01 80 00 02 14 A3 E0 76 00 0B 10 04 00 22 FF 0040 03 00 00 FF FF 00 3F 35 2D 24 80 40 90 95 00 A3 0050 FF FF 00 FF FF FF 00 80 C1 6F FF FF 19 44 04 05 0060 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 0070 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 2D FF 0080 04 FF 04 FF 00 00 3C 20 01 9B 01 01 3C 3C 04 04 0090 04 FF 30 00 00 01 01 3C 43 17 00 00 2E FF FF C1 00A0 84 D8 CF CD D0 FF B7 2D 1F 2A 7C DA 00 10 1A 02 00B0 02 01 80 00 02 14 A3 E0 76 00 0B 10 04 00 22 FF 00C0 03 00 00 FF FF 00 3F 35 2D 24 80 40 90 95 00 A3 00D0 FF FF 00 FF FF FF 00 80 C1 6F FF FF 19 44 04 05 00E0 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 00F0 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 2D FF 0027 0150 0250 007D 007E T: 45 36 12 0 45 T: 45 36 12 0 45 T: 45 35 12 0 45 T: 45 35 12 0 45 T: 45 36 12 0 45 T: 45 36 12 0 45 T: 45 35 12 0 45 T: 45 35 12 0 45 T: 45 36 12 0 45 T: 45 36 12 0 45 Bnk0 FF FF 00 FF FF FF 00 80 C1 6F FF FF 19 44 04 05 Bnk1 25 00 00 4B 00 50 04 BE FF FF FF FF FF FF FF FF Bnk2 0C 80 00 4B 00 50 1B 00 FF FF FF FF FF FF FF FF Bnk3 03 02 00 02 07 07 01 00 00 02 00 D0 7F 0F 00 00 Bnk4 00 13 FF 00 00 00 00 03 42 DE 1D AB 09 5F 20 7F Bnk5 D5 03 00 6E 20 94 10 A4 41 40 00 00 00 00 00 00 Bnk6 7F 7F 7F 7F 7F 7F 15 F9 07 AA 15 6F 00 00 05 FE Reg$20 CPU Core: r = 132, r*0.016 = 2.11 Reg$21 CPU Aux: r = 216, r*0.016 = 3.46 Reg$22 +3.3 V: r = 207, r*0.016 = 3.31 Reg$23 +5 V: r = 205, r*0.016 = 3.28 Reg$24 +12 V: r = 208, r*0.016 = 3.33 Reg$25 -12 V: r = 255, r*0.016 = 4.08 Reg$26 -5 V: r = 183, r*0.016 = 2.93 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: P6T-Deluxe ICPU/VCPU/PCPU: 9 / 87 / 54022 CPU Temperature : 44.0 C MB Temperature : 45.0 C CHASSIS1 FAN Speed: 5443 RPM CHASSIS2 FAN Speed: 0 RPM CHASSIS3 FAN Speed: 1520 RPM CPU FAN Speed : 2008 RPM POWER FAN Speed : 1371 RPM +12 Voltage : 12.137 V +3.3 Voltage : 3.280 V +5 Voltage : 4.998 V Vcore Voltage : 1.056 V CPU Temperature : 47.5 C MB Temperature : 45.0 C Chassis1 Fan Speed: 5625 RPM Chassis2 Fan Speed: 0 RPM Chassis3 Fan Speed: 1520 RPM CPU Fan Speed : 2008 RPM Power Fan Speed : 5443 RPM +12V Voltage : 12.137 V +3.3V Voltage : 3.280 V +5V Voltage : 4.998 V Vcore Voltage : 1.056 V CPU PLL : 1.800 V CPU Voltage : 1.22500 V DRAM Bus Voltage : 1.600 V ICH PCIE : 1.500 V ICH : 1.100 V IOH PCIE : 1.500 V IOH : 1.100 V QPI/DRAM Core Volt: 1.20000 V CHA CTRL : 0.500 X CHA DATA : 0.500 X CHB CTRL : 0.500 X CHB DATA : 0.500 X CHC CTRL : 0.500 X CHC DATA : 0.500 X BCLK Frequency : 134.00 MHz CPU Ratio : 20x Quote
Fiery Posted September 17, 2011 Posted September 17, 2011 It's not an AIDA64 bug fortunately That is a known peculiarity of Asus P6T boards. PC Probe II reconfigures the sensor chip to use a certain temperature offset to correct the temperature reading measured by the sensor chip. We prefer to display the real temperature that the sensor chip provides, without any weird offsets applied. Regards, Fiery Quote
