fixed: AIDA64 does not show AquaStream Ultimate readings with aquasuite X.6
1 hour ago, novax said:
Hello
Without any information in Aida64 version 6.10. of Aquasuite in his new 6x version.
regards
Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
5 hours ago, novax said:
perdón pero no encuentro las opciones que me indica.
sigo sus indicaciones.
perdón por mi torpeza
No problem.  I think we've managed to fix the issue in the latest beta version of AIDA64 Extreme available at:
Let me know how it works.
18 hours ago, Fiery said:
Thank you.
With this update it still doesn't show anything.
I use aquastream ultimate
in the 6 X version of aquacomputer
System Debug
3 hours ago, novax said:
Thank you.
System Debug
Please try to perform the dumps that I asked for in my first post in this topic.  You can have the debug popup menu pop up if you use the Ctrl + Alt + D key combination.  When that menu pops up, select System Debug, then USB Dump to make the USB dump.  Then also select Sensor Debug --> Aqua Computer Dump in order to have the other dump.
On ‎10‎/‎18‎/‎2019 at 11:43 AM, novax said:
Yes, thank you.  Make sure to upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
