Mors Posted October 30, 2019 Posted October 30, 2019 Hey all, For some reason I can't get the temps of my ram when I can get it with another solution. The Trident Z RGB DC is the double capacity ram and only has 2 sticks but 4 rows of storage if you know what I mean. It's a 64g kit in 2 physical dimms. I would love to see if we can look at adding those temps to the list of sensors. Blah sorry this should be in bugs section. Quote
Fiery Posted October 30, 2019 Posted October 30, 2019 3 hours ago, Mors said: Hey all, For some reason I can't get the temps of my ram when I can get it with another solution. The Trident Z RGB DC is the double capacity ram and only has 2 sticks but 4 rows of storage if you know what I mean. It's a 64g kit in 2 physical dimms. I would love to see if we can look at adding those temps to the list of sensors. Blah sorry this should be in bugs section. Please try to enable the option called DIMM thermal sensor support on the page AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes. Let me know if it helps. I've moved your topic under Bug Reports Quote
Mors Posted October 30, 2019 Author Posted October 30, 2019 (edited) I did that and not seeing any dimm temps. I had it on all along. I see voltage and current for the dimms but nothing for temps. In fact I don't see dimms individually listed too. one of each measurement. volts and current. This is all I see in the sensor list. Edited October 30, 2019 by Mors Quote
Fiery Posted November 1, 2019 Posted November 1, 2019 On 10/30/2019 at 7:21 PM, Mors said: I did that and not seeing any dimm temps. I had it on all along. I see voltage and current for the dimms but nothing for temps. In fact I don't see dimms individually listed too. one of each measurement. volts and current. This is all I see in the sensor list. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Mors Posted November 1, 2019 Author Posted November 1, 2019 ------[ Versions ]------ Program Version : AIDA64 Extreme v6.10.5200 BenchDLL Version: 4.5.811-x64 Windows Version : Microsoft Windows 10 Pro 10.0.18362.418 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ROG Maximus XI Apex Motherboard Chipset : Intel Cannon Point Z390, Intel Coffee Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG MAXIMUS XI APEX DMI MB Version : Rev 1.xx DMI MB Serial : 181242565400383 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1302 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : ACPI SMBus Port : EFA0 Can Have SPD: Yes Scan Type : Full *** SMBus Semaphore Disabled = 0 Dump took 12.5 sec This is the SMB full dump.. wierd it says it took 12.5 seconds do dump the but in reality in only took 1/2 a second Quote
Fiery Posted November 12, 2019 Posted November 12, 2019 On 11/1/2019 at 9:53 PM, Mors said: ------[ Versions ]------ Program Version : AIDA64 Extreme v6.10.5200 BenchDLL Version: 4.5.811-x64 Windows Version : Microsoft Windows 10 Pro 10.0.18362.418 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ROG Maximus XI Apex Motherboard Chipset : Intel Cannon Point Z390, Intel Coffee Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG MAXIMUS XI APEX DMI MB Version : Rev 1.xx DMI MB Serial : 181242565400383 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1302 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : ACPI SMBus Port : EFA0 Can Have SPD: Yes Scan Type : Full *** SMBus Semaphore Disabled = 0 Dump took 12.5 sec This is the SMB full dump.. wierd it says it took 12.5 seconds do dump the but in reality in only took 1/2 a second Try to disable the option called SMBus access through ACPI (Asus motherboards) in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes. Quote
Mors Posted November 12, 2019 Author Posted November 12, 2019 Looks like it worked I see for Dimm Temps now. Quote
Fiery Posted November 14, 2019 Posted November 14, 2019 On 11/12/2019 at 11:53 PM, Mors said: Looks like it worked I see for Dimm Temps now. Sounds great Quote
