Spectrum Posted September 26, 2011 Posted September 26, 2011 Voltage Values is incorrect by this motherboard, on program HWInfo32 sensor detected correct voltages. Please fix it this. Quote
Fiery Posted September 26, 2011 Posted September 26, 2011 We've implemented sensor tweakings for M5A97 boards. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.co...39q1ynp3i9xuzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Please make sure to compare AIDA64 readings against Asus' own monitoring software (Asus AI Suite 2 or PC Probe II) only. Other 3rd party software may or may not provide 100% accurate readings. Thanks, Fiery Quote
Spectrum Posted September 27, 2011 Author Posted September 27, 2011 Nothing has changed AI_Suite_II detected voltages correctly. 12V - 12.20V, 5V - 5.10V, DRAM - 1.525V, VCORE 1.425V and etc. Quote
Fiery Posted September 27, 2011 Posted September 27, 2011 Thank you. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Thanks, Fiery Quote
Spectrum Posted September 27, 2011 Author Posted September 27, 2011 ASUS Sensor ISA Sensor Dump isasensordump.txt Quote
Fiery Posted September 28, 2011 Posted September 28, 2011 Thank you. We've fixed the sensor readings in the following new beta release of AIDA64 Extreme Edition: http://www.aida64.com/downloads/aida64extremebuild1641xc8yz5fwkpzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
Spectrum Posted September 29, 2011 Author Posted September 29, 2011 Yes, all sensors its ok. Thanks you! Quote
