I renewed my AIDA64 a few days back, and just reinstalled it. I customarily run the  OSD panel. I was setting that up when I noticed the CPU temps aren't there (but the GPU is).  The fan speed for the GPU is there, but the rest of the fans aren't. They all showed up fine with the old version. I've deinstalled it and reinstalled it a number of times, restarting after each try. I'd appreciate some assistance.
Have you tried to restart Windows after the upgrade?
On 12/12/2019 at 5:25 PM, Jimmy Twocrow said:
Yep. I dutifully restarted the PC after the install. When things didn't display, I uninstalled, ,rebooted, installed, rebooted. Still no joy.
