fixed: ASRock TRX40 Taichi Missing Info Benchmark
The Cache & Memory Benchmark is not showing any info for the Memory Bus or Memory Type. None of the versions are showing the memory info. I am a memory review writer and this is making it impossible for me to write reviews.
Please see the attached picture.
I've sent you an email about this issue to accelerate fixing the problem for you.
  • 5 weeks later...
Meanwhile the bug fix has been rolled out as a new AIDA64 beta update:
