Guest Posted December 24, 2019 Posted December 24, 2019 Hey there. I'm currently working on my sensor panel and I would like to include the virtual memory (free/used/utilized) but it seems like something is "wrong" with that sensor. My page file is set to ~32GB but the sensor is showing me about ~65GB. Is there something that I don't understand and everything is working fine or is that a bug? And if thats working as intended, is there any way to see the actual size/utilization of the page file? Quote
Fiery Posted December 24, 2019 Posted December 24, 2019 2 hours ago, Backslash said: Hey there. I'm currently working on my sensor panel and I would like to include the virtual memory (free/used/utilized) but it seems like something is "wrong" with that sensor. My page file is set to ~32GB but the sensor is showing me about ~65GB. Is there something that I don't understand and everything is working fine or is that a bug? And if thats working as intended, is there any way to see the actual size/utilization of the page file? Virtual Memory -- as it is managed by the Windows kernel -- includes physical memory and any swap spaces. You can use the Correction facility (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction) to substract the amount of physical memory you've got from that amount to get the total swap space. That wouldn't be much help to get the actual swap space utilization though. Quote
Guest Posted December 24, 2019 Posted December 24, 2019 Would there be any way to implemenmt a fix then to make it possible to see only the swap? Quote
Fiery Posted December 30, 2019 Posted December 30, 2019 On 12/25/2019 at 12:05 AM, Backslash said: Would there be any way to implemenmt a fix then to make it possible to see only the swap? We haven't found a reliable way to do that yet. Quote
Guest Posted January 1, 2020 Posted January 1, 2020 Okay, thank you. I'll just keep an eye on it every now and then and maybe one day in the future I'm lucky Quote
