Hi,
my system is a Dell XPS 17 with Intel i7 Sandy Bridge 2630, chipset Intel H67 B3 revision and nVidia GT555M. Every driver is update to the last version from the manufactured (Intel and nVidia) website.
I've small freezes of the PC when I open sensor window or any other feature with temperature or other infos (OSD, sistem tray, windows gadget). The freezes appear when the infos of those windows refresh.
If I disable the option "Load Kernel drivers" under configuration tab the freezes disappear, but also almost any infos on sensor pannel disappear too.
Can someone help me to solve it? I have Aida64 1.85 and I wish to keep it solving this problem.
Please try to disable Dell SMI sensor support in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes.
Let me know if it helps.
